Originally posted by: Millennium
You car must keep the reflective material no matter what.
The tail lights are identical to the stock lights except for the top being clear instead of pink. As for the front, I removed a plastic amber strip that may have been reflective. Heres what I've found from the vehicle code so far that applies:
25100. (a) Except as provided in subdivisions (b) and (d), every
vehicle 80 inches or more in overall width shall be equipped during
darkness as follows:
(1) At least one amber clearance lamp on each side mounted on a
forward-facing portion of the vehicle and visible from the front and
at least one red clearance lamp on each side mounted on a
rearward-facing portion of the vehicle and visible from the rear.
(2) At least one amber side-marker lamp on each side near the
front and at least one red side-marker lamp on each side near the
rear.
(5) Combination clearance and side-marker lamps mounted as
side-marker lamps and meeting the visibility requirements for both
types of lamps may be used in lieu of required individual clearance
or side-marker lamps.
25950. This section applies to the color of lamps and to any
reflector exhibiting or reflecting perceptible light of 0.05 candela
or more per foot-candle of incident illumination. Unless provided
otherwise, the color of lamps and reflectors upon a vehicle shall be
as follows:
(a) The emitted light from all lamps and the reflected light from
all reflectors, visible from in front of a vehicle, shall be white or
yellow, except as follows:
all reflectors, visible from the rear of a vehicle, shall be red
except as follows:
(1) Stoplamps on vehicles manufactured before January 1, 1979, may
show yellow to the rear.
(2) Turn signal lamps may show yellow to the rear.
(3) Front side marker lamps required by Section 25100 may show
yellow to the rear.
24953. (a) Any turn signal system used to give a signal of
intention to turn right or left shall project a flashing white or
amber light visible to the front and a flashing red or amber light
visible to the rear.
