My SCSI RAID card will not work
DJE007
503
My SCSI RAID card will not work in the motherboard
I have a Mega RAID Elite 1600 I have the current BIOS/Firmware
111U 08/20/04
I can't ctrl M to get in the card bois
It will work in a diff motherboard
Any ideas
I am using IDE at the moment
Boonesmi
14,448
have you tried installing it in a different slot?
also make sure in the bios that you have the "bootable add-in cards" selected in your boot order
DJE007
503
have you tried installing it in a different slot? YES
also make sure in the bios that you have the "bootable add-in cards" selected in your boot order YES
The card works as well I have tested in other systems
Boonesmi
14,448
is the mobo bios up to date? (i have teh same motherboard, and i dont think ive seen a bios update since back near the beginning of the year :( )
but it could very simply just be a compatability problem that wont be resolved until MSI releases a bios update to fix it
