wow...i have a toshiba modem as well and USED to get those problems a lot. RR highly suggests that you run the modem via ethernet, as i was doing. The problems seemed to go away for awhile. Now the problems are back (as of three days ago). It's really annoying b/c i originally thought the problem was a compatibility issue with winxp and my modem, so i switched to win2k. Low and behold, the problem is still here. The easiest fix i've found is to disconnect power to the modem (via the power cable *NOT the COAX*) and unplug it for a quick second, then plug it back in. My system resources hang while my cpu is @ 100% and my system freezes for a minute or two, but it usually corrects itself. Occasionally, the modem WON'T restart itself and i have to either log off or restart my rig. BTW...timewarner/RR has NO information on this topic and is unable to help you. They told me i was some kind of freak case and that they'd never heard of this before. And a quickie...i'm nowhere near ANY military base.
-=bmacd=-
