mikeymikec
My router has cooling vents on the top, which is good to some extent for ventilation, but on the flipside surely it's also a good way for dust to get in and help heat components that presumably prefer ventilation. My only thought for stopping dust entering while allowing ventilation from the inside is some kind of miniature DIY stand that allows heat to flow out (like a table with very small legs, perhaps 1cm long) while acting as a barrier to some extent for dust to get in.
On my PC I use magnetic dust filters but I think the router's outer casing is all plastic.
