My right front passenger tire on my CRV is flat
krunchykrome
13,413
My front right (passenger) tire on my 2008 CRV is flat, and it's currently riding on a spare. I plan on scheduling an appointment to take it into the shop to get a new tire. Do I need to replace the other front tire (left driver) also?
UPDATE: 07/09/09
My wife took the CRV to MrTire this morning. They're saying that we need to replace all 4 tires since the car has about 27k miles on it and it's AWD.
Typically for AW/4W vehicles, all 4 tires need to replace at the same time, unless the tires are fairly new. I did a quick google search and read a few opinions on this, and most people agree.
So we're going to have all four replaced. They're having a special, so it's going to run us about $500.
lurk3r
981
Depends how worn it was, on an AWD car you don't want much difference in the size of the tires.
evident
12,096
710
get em all replaced if the treads are low
i hate riding on uneven tires.
sdifox
98,948
17,375
how long did you ride the spare? as long as the wear between the 2 fronts are close, you are fine, assuming you can repair it. If it is not pluggable, you have to replace at least 2.
JulesMaximus
74,544
924
It is unlikely that he'd even notice it with that car...especially if the other tires aren't very worn.
Edit-Dave, if they do end up replacing both front tires have them rotate them to the rear of the vehicle. Next time you rotate them I'd look seriously into getting new front tires too as you don't want worn tires in the rear and new tires up front.
geno
25,074
4
Your owner's manual will tell you what the tolerance is for tread difference between driven wheels. It should, at least.
Sukhoi
15,342
104
If the 3 remaining tires had a lot of tread left and you could find an exact replacement tire, you could have it shaved down. But at 27K you're probably just going to want to replace all 4.
thescreensavers
9,916
look at prices on tire rack might be alot cheaper. Tire Kingdom had a tire for 169 +installation tire rack had them for 99 big difference when buying all 4.
Heller
6,551
Try to find a used one with comparable tread?
Friends s10 extreme needed 1 one after he got flat (he put tires on it 35k miles ago) took it to friendly tire, found a comparable tire and he got away with it for $25 bux
The CRV is a very common vehicle, I'm sure you can find a used tire easily .
krunchykrome
13,413
I think I needed 4 new tires though. The S10 extreme is RWD
Gibson486
18,378
Originally posted by: nakedfrog
27k doesn't seem like they should be due for replacement yet to me...
have you ridden new cars lately? They come with the worst tires that wear out fast.....even then, on 4 wheel drive cars, you want all tires to have the same tread life.
Gibson486
18,378
$99 x 4 + shipping + installation x 4, but yeah, it may still come out cheaper.
Fenixgoon
32,886
12,166
yep, tirerack is cheaper for the tires, but once you add mounting and balancing, it's not always cheaper
krunchykrome
13,413
I'm a little dissapointed with MrTire
We paid about $550 for 4 tires+allignment. This included a special, buy 3 tires get 1 free.
I thought it was a decent deal. Turns out that they put on Goodyear Integrity tires on my CRV and their list price for them was $144 each.
So essentially, what I paid for was (estimate, I vaguely remember these numbers):
Goodyear Integrity tires x 3 @ $144 = $432
Allignment 85
Labor 8
Tax 25
Total $550
Last night, I did some reviews on the Goodyear Integrity tires, and other places are selling this tire for $99-$109 each. Also, this tire has horrible reviews.
So I got 4 crappy tires on my CRV at a price I thought was a bargain, but was actually higher than competitors. :(
krunchykrome
13,413
I did, but it was after the fact.
And the car was driving on a spare, and we needed it fixed ASAP
vshah
19,003
24
Allignment 85
Labor 8
Tax 25
Total $550
144 each! that basically nullifies the "free tire" right there :(
rockyct
6,656
32
Just recently I got a flat on my 08 mazda 3 that has 29,000 miles. I wasn't that bothered because I was planning on getting new tires as the tread was down to almost the bare minimum. The new tires I got have a non-prorated tire hazard warranty (they'll replace it for free if there's legal tread left) and 60,000 mile prorated warranty, so they'll probably last quite a bit longer. They are rated very highly too.
