- Aug 16, 2008
- 5
- 0
- 0
I just built my first PC with an Intel Q9550 (not over-clocked). I am concerned that I didn't apply the thermal paste to the CPU properly since I had never done that before.
At idle, the BIOS says the CPU temp is 57C. Speedfan says it is 49C.
Under heavy load while rendering high-definition video, Speedfan says core 0 hit 74C with the other cores a couple degrees cooler. I think rendering pushes all 4 cores to 100%.
This is with the CPU fan set to a variable speed where it speeds up as the temp rises. It runs fast and loud while rendering video.
Are these temps acceptable?
