My problem with case reviews
pmv
15,142
10,044
This probably isn't an original complaint in general, sorry.
In trying to choose a case I find case reviews quite frustrating in that they all seem to put a great deal of effort into measuring and tabulating temperatures, but almost invariably just use the stock fans to do so. To me this seems to render the whole exercise a bit futile. Especially as these days cases often come with up to 7 or more fan mounts, but only 2 or 3 actual fans.
In particular, reviews often measure temps with the side panel mount left unused, and it seems to me this therefore tells me almost nothing about how good the GPU cooling in particular would be if you at least filled that mount. All you get are predictably better gpu temps on cases that include that fan by default, with no clue as to how the other cases would do if you spent a few bucks filling that mount.
I realise there's a rationale for this, in that they are reviewing the case 'as is' and any extra fans will add to the cost, but I reckon I'm capable of working that out and factoring it in to the bang-for-buck calculations.
Specific example - fractal R2 midi vs R4 - the former has no side fan, but comes with 3 fans by default rather than 2, and the latter comes with noise reduction material over most of the fan slots. But which would give better temps if you added at least a couple more fans from stock? I've no idea.
answ3r
27
Yeah, I see where you're coming from. It would definitely be nice if reviews included some data with a set of high quality (or even mid-range) fans.
pauldun170
9,563
5,814
Whenever I get a new case, first thing I do is replace the fans that come with it. ThenI'll add additional as needed.
BonzaiDuck
16,890
2,208
No argument there. I check the reviews for cases of interest, but the airflow requirements or potentials for ATX cases hasn't changed much over the years. I just need to look at the various photos on some site like Newegg, and I can tell whether a case offers me what I need and want.
T_Yamamoto
15,007
795
You can look around in Overclock.net since people show their rigs off there.
Most people don't add extra fans or change them because they don't need to.
pmv
15,142
10,044
On the general topic, I did find this:
http://www.bit-tech.net/hardware/2012/02/10/the-big-cooling-investigation/1
to be interesting. Gives some sense of how much one can expect temps to drop as more fans are added. Obviously it still leaves a lot out regarding the effectiveness of different types of fan (and what the effect of differeint fan speeds might be).
Interesting to me that the side-panel fan is by far the most effective until you have really strong front-to-back airflow.
See, with the fractal cases, I was wondering to what extent the partially closed front (as opposed to a mesh one) hampers cooling, but its hard to tell from reviews that only test with a couple of fans anyway.
Draygonn
28
I check with case owner's for real world performance. I use case reviews only to see what I can fit and where.
JEDIYoda
33,986
3,321
The truth of the matter is most people don`t add extra fans because they really have no clue about their case temps and as long as the computer works and everything is fine they are not going to sweat to what some of us would call high case temps!!
YES!! You are correct when you say because they don`t need to!! That need being as long as the computer works they are happy!!
T_Yamamoto
15,007
795
The percentage that add fans or swap them probably are miniscule compared to those who keep it at stock.
