My power supply w/built in fan is in bad shape. I want to replace it with a QUIET model....
rnmcd
I will be slowly rebuilding my PC. Since my power supplyis failing I will start with replacing that.
I want this next PC to be really quiet...do you have a power supply that is quiet that your recommend?
Thanks!
I want a minimum of 400watts for the PS. Regarding price, is it always more quality for more money?
Generally the more you spend the better the quality with PSUs. If you're looking for quiet, consider getting one with a single 120mm or 140mm fan rather than dual 80mms or the like. There are also completely fanless power supplies available if your budget allows.
Originally posted by: Anubis
Antec Truepoer 430 watt, mine is super quite, hard to tell its on actually
ditto, you could also just replace the fan in your PSU it's not too hard to do.
That's a good idea but this thing was never very quiet even when it was new.
I was looking at the Seasonic Super Silencer 400....anyone ever heard of it? It's about $90. How much for the Antec Truepower 430?
69.99$
The Super Tornado series is supposed to be even better (I have one, it's damn quiet), according to www.silentpcreview.com. They are pricey, but probably quieter than the Antec TruePower line.
Wow, you're not having any power problems with just 300 watts?
do you mean replace the fan inside the PS case?
Yeah. But be careful and do some research first...even switched off there can be enough juice in the PS to suck the paint off your house and give you a permanent orange afro. NMBs (if you can find them...Ebay?!?!) are awesome. Virtually silent yet they still push a decent amount of air.
