My POS soldering iron died - fix??
screw3d
6,906
It's such a simple thing I don't know how it could go wrong. It just won't heat up.
I opened it up, and there's nothing that looked broke. :confused:
To the trash can and to radioshack? :frown:
dighn
22,820
4
use a continuity tester?
if you think it's worth the trouble to fix a "pos soldering iron"
screw3d
6,906
LOL. It's just a live-ground connection on a heating element right? How on earth something so simple can get screwed up? confused;
Zorba
15,613
11,256
I got a craftsman soldering iron for 9 bucks 5 years ago, with a good stand. Never had a problem ;)
simms
8,211
Probably something wrong in the connection. You may want to solder it back together.
hehehehe... i'm too funny. :p
Analog
12,755
I moved away from the simple ones, I have owned a Metcal for over 10 years now, and it has run flawlessly.
cerebusPu
4,008
I recently got a Weller digital soldering station at work....and man oh man...it really beats my radioshack iron. Soldering is now fun!! I didnt understood the point of buying a $300 soldering iron but now i know its totally worth it. Now Im looking for a unit for home use. It needs to be temp controlled and performs like the weller but costs <$100.
element
Not to mention 4 posts too late.:D
shekondar
1,119
Like this?
arcas
2,155
I bought a relatively inexpensive Solomon soldering station from MPJA. Much better than the POS single-temperature Radio Shack iron I'd been using before. Probably no comparison to a $300 Weller station but at $50, I'm happy.
AlienCraft
10,539
Ok kids, here's the deal.....
If it has a removable / replaceable tip, over time the heating and cooling cycles can cause it to loosen slightly eliminating it's soldering capabilities. Also, scale can build up depending on the quality of metal, length of time left on, etc. reducing heat conducting ability.
Here's how to fix it......
Take the tip off of the element. Take steel wool to the threads and replace the tip, or clean the threads of the tip and re-use. A little wd-40 will help on that first re-heating.
