Originally posted by: funboy42
IMO belts should be illegal to put on ANY motor, its almost like a computer and electronic makers installing software that makes thier product you bought quit working after xxx period of time or use, forcing you bring it in and get the clock reset. They can easily use a chain, but why do that when you can use a belt instead forcing anyone who bought the car to bring it in and get the belt changed handing money over to them at a predetermined time. Every car with a belt at some point or another needs to have it changed no matter what, and then they punish you for driving your car till it breaks by making sure it does more damage to the motor, meaning, possible more money to them in repairs, or the chance you may buy another car off their car lot when you find out the bill to fix is now in the thousands.
So tell me, does that sound right? Why is it against the law for everyone else, BUT THE AUTO MAKERS, to do such a thing? Cannot tell me its cost effective to just make it so it uses a chain, then a belt, for I am sure ANYONE would gladly pay the extra $100 on the cost of the car knowing it had a chain, then knowing at 60K when there is no warranty, and they consider a belt replacement a wearable item not covered by any warranty, not even extended, they will have to get it changed costing them over $1000 to do it, or more then that in most cases.
But anyway, i agree, ban for you for showing just the motor and not the car, and the motor does look great, good for you doing it yourself. Any reason as to why it took 3 years though?
