My poor monitor :(
MagickMan
7,460
More specifically, a VRAM issue. Try more voltage to your GPU or lower the clocks, and clean the card too, and see if it helps. If not, get an RMA on that card if you can.
Quiksilver
4,725
You haven't been paying atention.
tweakboy = nonsensical answers and random gibberish.
Completely worthless and not knowledgeable about anything except his dad's P4.
I Know that :awe: but that answer was a little more comprehensible than his usual BS he posts.
tweakboy
9,517
www.hammiestudios.com
I trust you can build it for me phoenix,
Are you all using Psychic, and with what video card k 24 inch,,
I dont think you need to format, we just have to get to the root of the problem
Like,, where has it been living for its earlier life etc,, thanks
HurleyBird
2,801
1,528
Good monitor. I have one now retired to the recording computer. Definitely try it on another system, or at least with a new vid card, and if neither of those two options are available try underclocking yout gfx card, especially the memory.
Bill Brasky
4,324
Just stop.
Let us know if driver cleaner and a reinstall helps. Since the funny pixel moves with the webpage, it definitely sounds like a gpu/ driver issue, rather than a monitor issue. Did you make any system changes before the problem started?
