It hasnt done that before? I would think it was just a difference in reported clock to actual clock, but it shouldnt change on its own. Did you change memory or bios settings?
Don't worry about, it. You should think about getting rid of it soon anyways though. I would try a 1.6 applebred cpu for 40 bones and a 60 dollar nforce 2 board.
