- Oct 23, 2005
- 346
- 0
- 0
trying this idea in a few forums to get some general insight. alright heres my idea....sorry long post, feel free to knock any holes in it or apply suggestions so i know how worth while the idea is.
a 2 part PC
consisting of what i call a PC station (housing all the main components)
and a PC control base (houseing only dvd/usb ports/power and reset switch)
the main accessed things of a pc on a daily basis is the disk drive/usb ports/power and reset buttons, right? ..correct me if you disagree
so with that thought i imagined the benefits of seperating those main things from the typical tower case idea.
bare with me if you will
i would use a USB dvd drive (perfromance of a dvd drive isnt often a necessity)
a USB hub and some standard power and reset buttons.
i would use extension cables like this:
http://www.xpcgear.com/sabrentusbexc2.html
they also have sleeving and lots of good mod parts i may include, i'd also port female connectors onto control base for quick disconnect if i need to move it around.
or maybe something wireless...not sure how that could be implemented
for power/reset, i'd use 22 guage copper with female connector ported onto case and male for external wire for quick unplug
a dvi 16ft extension
http://www.cablestogo.com/prod...at%5fid=3315&sku=29530
and sound card 1/8 plug extensions shouldnt be hard to find
heres the benefits as to why i think this is a good idea.
1. tons more desktop space...imagine using a PS2 case to house your dvd,usb and power buttons, or other sleek, small units
2. far less noise. you wont have to hear your PC fans, hard drives..etc right there so close to you, maybe with up to 80ft worth of extenstions you can put the pc station in a closet or something.
3. much easier to open and close dvd drive and plug in usb slots...seriously how many of you have to reach, duck, bend sideways from your chair to access usb slots or your dvd's? even a mid tower right next to your monitor is kinda tall, takes up fair space and noisy just to have ready access to what you need.
4. makes desktop space much leaner, sleeker with less "seen" wires, imagine your friends suprise when you load up a game like fear at max graphics and all they see sitting on your desk is something like a PS2 or whatever housing you use causing one to wonder how your getting all that power from such a small PC.
on my tower side i'd use an empty slot cover, drill a hole in it big enough to run the power wires to the mobo again with female/male connectors integrated onto the slot cover, dvd drive of course to an empty usb slot
with up to 80 feet potential of usb wire extension (as marketed at xpcgear.com) it should give alot of freedom as to how it all gets setup, i'd likely use my old PS2, gut it, to house the control base devices.
i've always been kinda envious of how small and sleek the mac mini is and other ITX cases, plus i've always hated the case noises, so to keep a powerful gaming rig i think this might be the best bet
so how doiable do you guys think this might be?
any other cons or pros i'm not thinking of?
a 2 part PC
