Question My pc build for review
lesiuu
Hi guyss! I create my budget pc build 'cause i'd like to upgrade my currently pc.
My budget is 900$ approximately.
If you could review my build and write me what can i change there I will be really greatfull! Thank you in advance!
My build: https://pcpartpicker.com/list/N2b6bL
(I will add SSD from my currently pc to new pc so I chose only 500 gb./ In future I will buy M2 storage, but I have limit low budget for now)
Peace out!
28,916
14,191
Haha whyy
See my edited post.
For example: https://www.microcenter.com/product...ies-32gb-ddr5-6000-kit,-computer-build-bundle
Ryzen 7 7700X, B650 board with WiFi, and 32 GB DDR5 for $400
--> Would give you some room to upgrade the processor later, if you want, since AM5 may be around for a while
12600KF bundle: https://www.microcenter.com/product...s-v-16gb-ddr4-3200-kit,-computer-build-bundle $250
12700K bundle: https://www.microcenter.com/product...s-v-16gb-ddr4-3200-kit,-computer-build-bundle $300
lesiuu
I think I don't need Wifi in my board. I wonder this is additional costs for me now. I will only remind I have low budget for this build, and for sure I will purchase DDR4
Dec 10, 2005
28,916
14,191
Sure. Just pointing out the bundles could be a better value/deal than what you put together. The wifi isn't necessarily an extra cost there.
DDR5 and DDR4 are also pretty comparable in price, so that isn't really a savings.
Reactions: bigboxes
manly
13,320
4,094
OP never confirmed if he's close to a Micro Center, or even in the U.S.
At any rate, the Ryzen 7 7700X bundle is down to $365, one of the best values getting into AM5. It had been at $400 since last summer (with an occasional sale), so it was hard to recommend as some components have gotten cheaper over time.
The Intel i5-12600KF bundle (with a different motherboard) has dropped to $233:
19,203
My recommendation: https://pcpartpicker.com/list/9qy3Jy
Don't go with Intel. It's a dead end. On AM5, you could upgrade to a Zen 5 CPU in 2025 or 2026 and get a crazy speed boost in your games.
Replaced your 8GB card with a 16GB one. VRAM is important going forward. It will help your card stay relevant longer.
