My P180 FINALLY done **PICS**
JBDan
2,333
Originally posted by: CraKaJaX
I was just thinking about removing the bottom fan ( the one that belongs there.) and running the PSU wires under there and up the other sliding door near the HD cage and straight up. Do you think it would look better than all those PSU wires sitting on top of the sliding door?
I think that would work nicely. It would give a neater appearance and the 120mm fan on the psu is sufficient by itself down there. No need for any extra fans at all in the bottem chamber the way you have your P180 setup. I like the pics :) Well done.
CraKaJaX
11,905
148
101
Can't wait to see your pics. My fan controller comes tomorrow.... ups never came today :|
JBDan
2,333
lol ^^^ ????
Fullmetal Chocobo
Moderator<br>Distributed Computing
Moderator
May 13, 2003
13,704
7
lol ^^^ ????
Finally, I meet someone as impatient as I am. So how much work do you have left on this, other than the fan controller? I'm at odds right now trying to figure out what I should upgrade. It sucks.
Tas.
CraKaJaX
11,905
148
101
i'm debating.... PSU cables running through the bottom chamber with the fan out of there (the nexus and stealth I put in there on my own will still be there) or run the PSU cables like they are.... in the top chamber sitting on top of the sliding door. what do you think?
Fullmetal Chocobo
Moderator
May 13, 2003
13,704
7
What kind of space is going to be available for ventilation? Will one setup (removing the fan) have more ventilation than the other? I would definitely go for function over form. Basically, is it between looking pretty or working better, or just deciding which one over another...
Tas.
EDIT: for clarification
twitchee2
2,135
can you get a pic of the who case with the rigth side panel off? the side w/o the window i woul dliek to see your cable mangment on that side.
Maluno
697
Wow, that is probably one of the best wiring jobs I've ever seen... GJ! :thumbsup:
CraKaJaX
11,905
148
101
thanks alot, my fan controller is in and some fans are hooked up, except i'm waiting for my Y splitters to get here so I can have all of my fans hooked up. and I need to sleeve some of the cables still.... pics will be up tonight without the Y splitter :)
CraKaJaX
11,905
148
101
Fan controller is installed.... ran out of sleeving, so I went to some tubing. Let me know what ya think....
Pics:
8
Basically done with everything now..... only thing that isn't hooked up is the Nexus on the bottom, but it's ready to be when I get everything delivered :D
scrawnypaleguy
1,036
Sigh.... it's your computer dude, but I still cannot comprehend the reasoning behind an 80mm fan 2 cm away from a 120, which is in front of another 120, which is cooling a psu that has it's own fan. Nice work nonetheless, I like the tubing. Where did you get tubing that small in diameter? I could use some of that stuff.
Fullmetal Chocobo
Moderator
May 13, 2003
13,704
7
Pics:
8
Still need a shot or two from all the way out, and not zoomed in... Very nice from the pics, but I need a basis of comparison...
Tas.
Fullmetal Chocobo
Moderator
May 13, 2003
13,704
7
there you are agian. always asking for more :|
Well, if someone has to poke and prod you to show off your machine, then so be it... But atleast give us material for the Dynamix scale rating. *eg*
JBDan
2,333
Pics:
8
Man it looks killer CraK! You have done your homework. I love those right angle sata connec's. Good lookin pc dude :p
CraKaJaX
11,905
148
101
After debating what to do because of my idling temps @ 36c.... I decided to go to work. I had my HD's in the top chamber -- BAD mistake. I HIGHLY recommend you put them in the bottom. I kept my 80mm Vantec stealth fan in the bottom infront of the HD's as an intake blowing over the HD's which blows into a 120mm CM Led fan which then blows out the back. I'm idling @ 31c right now with my XP-120 /w a Panaflo U1A on it. I took a few pics here --
Pics:
8
I can now rest... :laugh:
XARiUS
82
Yeah right! As soon as your UV cathodes arrive, you'll be back at it copy cat'ing my setup ;-) Can't wait to see it!
X
scrawnypaleguy
1,036
Impressive! That's amazing considering how much stuff you had to work with and the power supply you were using. I give it an A.
Fullmetal Chocobo
Moderator
May 13, 2003
13,704
7
Wow. Very nice. I can't upload your pics while I'm at work, but I will be doing a before / after kind of thing with your entry, since it is an update. It will atleast have links to the previous entry. :) Awesome work.
So there really isn't anything else you are going to be doing with your machine? Wow, I don't think I've ever heard of anyone actually being done. hehehehe
