I just got this stuff in today. Its flat acoustic foam 55" x 26". This stuff has the high rated noise reduction score, the only stuff i've seen that scored 0.80 NRC was convulted acoustic foam (eggcrate look) 3 inches thick! This stuff is only 1 inch thick but has the same acoustic value as the 3 inch convulted foam. From the pics you'll see that the top layer is skinned, this adds 25% percent more sound absorbsion, and also adds a smooth surface nice for you don't wanna loose airflow, but scuffs up real easy. This is open cell on the top and closed cell foam on the bottom. Its got sticky on one side so ya just slap it on, they cut it a little messy like...but that can be easily fix by trimming it...there about 2 inch excess of what the specs were, so that nice. Right now im painting my case and chopping it up some on some new mods adding ontop of my old filter mod i made to my enlight case a while back to make it work better and more attractive looking. Im working on it slowly i'll have a write up about all these mods in a few im taking im kinda taking it slow. Heres the pics of just the foam:
Wrapped up
Foam cells
Skinned top layer
Wrapped up
Foam cells
Skinned top layer
