- Jan 3, 2008
- 517
- 0
- 0
Not sure where to post this but I just built a new comp and it will not turn on.
the psu fan does not spin or anything.
Absolutely nothing happens.
Originally posted by: SkidPad
Alright, I gotta ask...is the "main" switch on the back of the power supply turned on? Most psu's come out of the box with the switch off...
Originally posted by: DSF
Your 450W is plenty of power, unless you got a defective unit. Unlikely, but possible.
Take the motherboard out of the case and rest it on a nonconductive surface, like the cardboard box it came in. Install only the bare necessities. Try to power the computer on again. If it powers on, then the problem was most likely a short against the back of the case. Check very carefully to make sure that your standoffs are in the right places, no screws fell behind the motherboard, etc.
Originally posted by: CatchPhrase
It works, turns out that i had to push the power button after hooking it up to the mobo.
:laugh:Originally posted by: Scoop
Yeah, you usually have to press the power button to power up the system..
