My New Radeon and My Low 3Dmark2001 Score
SpeedTester
995
Alright, I bought the Geforce 3 ti-200 from BB when they were 99.99 and my score was 4700 on 3dmark2001
I tried everything that was suggested with no luck. Now I just got a Radeon 8500 Retail and my score still seems
alot lower then the compared systems on Madonion. I love this card 3d is sharp and games run smooth but
my 3Dmark score isnt to par. Currently have the card at 300 Core / 600 Memory with no artifacts.
using powertools and Vsync and Fsaa is off. I'm willing to try anything someone suggests.
Thanks guys
3Dmark2001 Score is 6634
3DMARK2001 PROJECT FILE
PROJECT
Name My Benchmark
Description
Registration Name
Registration Key
3DMark Version 200
DISPLAY
Platform RADEON 8500/RADEON 8500LE
CPU Optimization D3D Pure Hardware T&L
Width 1024
Height 768
Depth 32 bit
Z-Buffering 24 bit
Texture Format Compressed
Buffering Triple
Refresh Rate 60 Hz
FSAA Mode None
OPTIONS
Show Title Screens Yes
Continuous Benchmark No
Benchmark Run Count 1
Demo Sounds Enabled Yes
Continuous Demo No
Game Sound Effects Enabled Yes
Game Music Enabled Yes
Game Detail Level Low
RESULTS
3DMark Score 6634
Game 1 - Car Chase - Low Detail 96.9 fps
Game 1 - Car Chase - High Detail 35.7 fps
Game 2 - Dragothic - Low Detail 123.2 fps
Game 2 - Dragothic - High Detail 68.3 fps
Game 3 - Lobby - Low Detail 99.0 fps
Game 3 - Lobby - High Detail 41.6 fps
Game 4 - Nature 26.6 fps
Fill Rate (Single-Texturing) 907.5 MTexels/s
Fill Rate (Multi-Texturing) 1912.6 MTexels/s
High Polygon Count (1 Light) 18.1 MTriangles/s
High Polygon Count (8 Lights) 9.8 MTriangles/s
Environment Bump Mapping 92.1 fps
DOT3 Bump Mapping 100.6 fps
Vertex Shader 78.5 fps
Pixel Shader 78.5 fps
Point Sprites 28.5 MSprites/s
SYSTEM INFO
System Info Version 2.0
Installation ID 0x51337ab5
OEM ID
CPU INFO
CENTRAL PROCESSING UNITS
Manufacturer AMD
Family Athlon(tm)
Internal Clock 1.48GHz
Internal Clock Maximum 1.48GHz
External Clock 144MHz
Socket Designation Slot A
Type Central
Upgrade ZIF Socket
Capabilities MMX, CMov, RDTSC, 3DNow!, Extended 3DNow!
Version Model 4, Stepping 2
CPUID 0x00000642
CACHES
Level 1
Capacity 128KB
Type unknown
Type Details unknown
Error Correction Type unknown
Associativity unknown
Level 2
Capacity 256KB
Type unknown
DIRECTX INFO
DirectX Version 8.0
DIRECTDRAW INFO
DirectDraw Version 5.1.2600.881
DISPLAY DEVICES
Description Primary Display Driver
Manufacturer ATI Technologies Inc.
Name RADEON 8500/RADEON 8500LE
Total Local Video Memory 64MB
Total Local Texture Memory 64MB
Total AGP Memory 0 bytes
Display Driver ati2dvag.dll
Display Driver Version 5.13.01.3286
Max Texture Width 2048
Max Texture Height 2048
Max User Clipping Planes 6
Max Active Hardware Lights 8
Max Texture Blending Stages 8
Textures In Single Pass 6
Vertex Shader Version 1.1
Pixel Shader Version 1.4
Max Vertex Blend Matrices 57
Max Texture Coordinates 6
Device ID 0x514c
Vendor ID 0x1002
Sub-System ID 0x013a1002
Revision 0x0000
DISPLAY MODES
320x200x16-bit RGB [565] @ 60Hz
320x200x16-bit RGB [565] @ 75Hz
320x200x32-bit RGB [888] @ 60Hz
320x200x32-bit RGB [888] @ 75Hz
320x240x16-bit RGB [565] @ 60Hz
320x240x16-bit RGB [565] @ 75Hz
320x240x32-bit RGB [888] @ 60Hz
320x240x32-bit RGB [888] @ 75Hz
400x300x16-bit RGB [565] @ 60Hz
400x300x16-bit RGB [565] @ 75Hz
400x300x32-bit RGB [888] @ 60Hz
400x300x32-bit RGB [888] @ 75Hz
512x384x16-bit RGB [565] @ 60Hz
512x384x16-bit RGB [565] @ 75Hz
512x384x32-bit RGB [888] @ 60Hz
512x384x32-bit RGB [888] @ 75Hz
640x400x16-bit RGB [565] @ 60Hz
640x400x16-bit RGB [565] @ 75Hz
640x400x32-bit RGB [888] @ 60Hz
640x400x32-bit RGB [888] @ 75Hz
640x480x16-bit RGB [565] @ 60Hz
640x480x16-bit RGB [565] @ 72Hz
640x480x16-bit RGB [565] @ 75Hz
640x480x16-bit RGB [565] @ 85Hz
640x480x16-bit RGB [565] @ 90Hz
640x480x16-bit RGB [565] @ 100Hz
640x480x16-bit RGB [565] @ 120Hz
640x480x32-bit RGB [888] @ 60Hz
640x480x32-bit RGB [888] @ 72Hz
640x480x32-bit RGB [888] @ 75Hz
640x480x32-bit RGB [888] @ 85Hz
640x480x32-bit RGB [888] @ 90Hz
640x480x32-bit RGB [888] @ 100Hz
640x480x32-bit RGB [888] @ 120Hz
800x600x16-bit RGB [565] @ 56Hz
800x600x16-bit RGB [565] @ 60Hz
800x600x16-bit RGB [565] @ 70Hz
800x600x16-bit RGB [565] @ 72Hz
800x600x16-bit RGB [565] @ 75Hz
800x600x16-bit RGB [565] @ 85Hz
800x600x16-bit RGB [565] @ 90Hz
800x600x16-bit RGB [565] @ 100Hz
800x600x16-bit RGB [565] @ 120Hz
800x600x32-bit RGB [888] @ 56Hz
800x600x32-bit RGB [888] @ 60Hz
800x600x32-bit RGB [888] @ 70Hz
800x600x32-bit RGB [888] @ 72Hz
800x600x32-bit RGB [888] @ 75Hz
800x600x32-bit RGB [888] @ 85Hz
800x600x32-bit RGB [888] @ 90Hz
800x600x32-bit RGB [888] @ 100Hz
800x600x32-bit RGB [888] @ 120Hz
1024x768x16-bit RGB [565] @ 60Hz
1024x768x16-bit RGB [565] @ 70Hz
1024x768x16-bit RGB [565] @ 72Hz
1024x768x16-bit RGB [565] @ 75Hz
1024x768x16-bit RGB [565] @ 85Hz
1024x768x16-bit RGB [565] @ 90Hz
1024x768x16-bit RGB [565] @ 100Hz
1024x768x32-bit RGB [888] @ 60Hz
1024x768x32-bit RGB [888] @ 70Hz
1024x768x32-bit RGB [888] @ 72Hz
1024x768x32-bit RGB [888] @ 75Hz
1024x768x32-bit RGB [888] @ 85Hz
1024x768x32-bit RGB [888] @ 90Hz
1024x768x32-bit RGB [888] @ 100Hz
1152x864x16-bit RGB [565] @ 60Hz
1152x864x16-bit RGB [565] @ 70Hz
1152x864x16-bit RGB [565] @ 75Hz
1152x864x16-bit RGB [565] @ 85Hz
1152x864x16-bit RGB [565] @ 100Hz
1152x864x32-bit RGB [888] @ 60Hz
1152x864x32-bit RGB [888] @ 70Hz
1152x864x32-bit RGB [888] @ 75Hz
1152x864x32-bit RGB [888] @ 85Hz
1152x864x32-bit RGB [888] @ 100Hz
1280x768x16-bit RGB [565] @ 56Hz
1280x768x16-bit RGB [565] @ 60Hz
1280x768x16-bit RGB [565] @ 75Hz
1280x768x16-bit RGB [565] @ 85Hz
1280x768x32-bit RGB [888] @ 56Hz
1280x768x32-bit RGB [888] @ 60Hz
1280x768x32-bit RGB [888] @ 75Hz
1280x768x32-bit RGB [888] @ 85Hz
1280x1024x16-bit RGB [565] @ 60Hz
1280x1024x16-bit RGB [565] @ 70Hz
1280x1024x16-bit RGB [565] @ 75Hz
1280x1024x16-bit RGB [565] @ 85Hz
1280x1024x32-bit RGB [888] @ 60Hz
1280x1024x32-bit RGB [888] @ 70Hz
1280x1024x32-bit RGB [888] @ 75Hz
1280x1024x32-bit RGB [888] @ 85Hz
1600x1200x16-bit RGB [565] @ 60Hz
1600x1200x16-bit RGB [565] @ 65Hz
1600x1200x16-bit RGB [565] @ 70Hz
1600x1200x32-bit RGB [888] @ 60Hz
1600x1200x32-bit RGB [888] @ 65Hz
1600x1200x32-bit RGB [888] @ 70Hz
TEXTURE FORMATS
32-bit ARGB [8888]
32-bit RGB [888]
16-bit RGB [565]
16-bit RGB [555]
16-bit ARGB [1555]
16-bit ARGB [4444]
8-bit RGB [332]
8-bit YUV [800]
16-bit AYUV [8800]
FourCC [DXT1]
FourCC [DXT2]
FourCC [DXT3]
FourCC [DXT4]
FourCC [DXT5]
3D Capabilities Edge Antialiasing, Hardware Transform and Lighting, Positional Lights, Subpixel Accurate Rasterizing, Range Fog, Vertex Fog, W-Fog, Specular Gouraud Shading, Anisotropic Filtering, Bilinear Filtering, Point Sampling, Trilinear Filtering, Additive Texture Blending, Dot3 Texture Blending, Multiplicative Texture Blending, Subtractive Texture Blending, Environmental Bump Mapping, Environmental Bump Mapping With Luminance, Cube Mapping, Factor Alpha Blending, Vertex Alpha Blending, Texture Alpha Blending, Texture Clamping, Texture Mirroring, Texture Wrapping, Rendering to a Window, N Patches, Mipmap LOD Bias Adjustment, Projected Textures, Volume Textures, Point Primitive Support, Full-Screen Anti-Aliasing, DXT Compressed Textures
DIRECTSHOW INFO
DirectShow Version 6.03.01.0400
REGISTERED DIRECTSHOW FILTERS
.RAM file Parser
AC3 Parser Filter
AC3 Source Filter
ACELP.net Sipro Lab Audio Decoder
ACM Wrapper
ASF ACM Handler
ASF DIB Handler
ASF DJPEG Handler
ASF ICM Handler
ASF JPEG Handler
ASF URL Handler
ASF embedded stuff Handler
ASX file Parser
ASX v.2 file Parser
AVI Decompressor
AVI Draw
AVI Splitter
AVI/WAV File Source
BDA MPEG2 Transport Information Filter
Color Space Converter
DV Muxer
DV Splitter
DV Video Decoder
Default DirectSound Device
Default MidiOut Device
File Source (Async.)
File Source (Netshow URL)
File Source (URL)
File stream renderer
IVF source filter
Indeo® audio software
Indeo® video 5.10 Decompression Filter
Internal Script Command Renderer
Line 21 Decoder
Lyric Parser
MIDI Parser
MJPEG Decompressor
MPEG Audio Decoder
MPEG Layer-3 Decoder
MPEG Video Decoder
MPEG-2 Demultiplexer
MPEG-2 Splitter
MPEG-I Stream Splitter
Microsoft MPEG-4 Video Decompressor
Microsoft Screen Video Decompressor
Multi-file Parser
NSC file Parser
Overlay Mixer2
QT Decompressor
QuickTime Movie Parser
SAMI (CC) Parser
VBI Surface Allocator
VGA 16 Color Ditherer
Video Renderer
Voxware MetaSound Audio Decoder
Voxware MetaVoice Audio Decoder
WM ASF Reader
WM ASF Writer
WMP CD Filter
WST Decoder
Wave Parser
Windows Media Audio Decoder
Windows Media Multiplexer
Windows Media Update Filter
Windows Media Video Decoder
Windows Media source filter
XML Playlist
MEMORY INFO
Total Physical Memory 768MB
Free Physical Memory 664.12MB
Total Pagefile Memory 1.83GB
Free Pagefile Memory 1.76GB
MEMORY ARRAYS
Max Module Capacity 512MB
Location unknown
Use unknown
Supported Error D&C unknown
Supported Speeds unknown
Supported Types unknown
Supported Voltages unknown
MEMORY SLOTS
Installed & Enabled Size 256MB
Form Factor DIMM
Frequency 0Hz
Slot BANK_0
Manufacturer Unknown
Type unknown
Enabled Size 256MB
Total Bit Width 0
Data Bit Width 0
Form Factor DIMM
Frequency 0Hz
Slot BANK_1
Type unknown
Enabled Size 256MB
Total Bit Width 0
Data Bit Width 0
Form Factor DIMM
Frequency 0Hz
Slot BANK_2
Type unknown
Enabled Size 256MB
Total Bit Width 0
Data Bit Width 0
MOTHERBOARD INFO
Manufacturer MICRO-STAR INTERNATIONAL CO., LTD
Model MS-6330
Version N/A
BIOS Vendor Award Software International, Inc.
BIOS Version Award Modular BIOS v6.00PG
BIOS Release Date 29/11/01
BIOS Charasteristics Plug and Play, Flash, AGP
CARD SLOTS
Number 0
Designation PCI
Type PCI
Characteristics unknown
Data Bus Width 16
Details unknown
Device Class unknown
Device Description
Device Revision 0x00000000
Device Manufacturer
Device Driver Date
Number 0
Designation PCI
Type PCI
Data Bus Width 16
Details unknown
Device Description
Device Manufacturer
Device Driver Date
Number 0
Designation PCI
Type PCI
Data Bus Width 16
Details unknown
Device Description
Device Manufacturer
Device Driver Date
Number 0
Designation PCI
Type PCI
Data Bus Width 16
Details Available
Device Description
Device Manufacturer
Device Driver Date
Number 0
Designation PCI
Type PCI
Data Bus Width 16
Details Available
Device Description
Device Manufacturer
Device Driver Date
Number 0
Designation PCI
Type PCI
Data Bus Width 16
Details Available
Device Description
Device Manufacturer
Device Driver Date
Number 0
Designation AGP
Type AGP
Data Bus Width 16
Details Available
Device Description
Device Manufacturer
Device Driver Date
SYSTEM DEVICES
Description VIA Standard CPU to PCI Bridge
Manufacturer VIA
Vendor ID 0x1106
Device ID 0x0305
Subsystem ID 0x00000000
Revision 0x0003
Description VIA Tech PCI to ISA bridge
Manufacturer VIA
Vendor ID 0x1106
Device ID 0x0686
Revision 0x0040
Description VIA Tech Power Management controller
Manufacturer VIA
Vendor ID 0x1106
Device ID 0x3057
Revision 0x0040
Description VIA CPU to AGP Controller
Manufacturer VIA
Vendor ID 0x1106
Device ID 0x8305
Revision 0x0000
MONITOR INFO
MONITORS
Name Optiquest V95
Manufacturer ViewSonic
Max Width 0
Max Height 0
OPERATING SYSTEM INFO
Operating System Microsoft Windows 2000
Version 5.0.2195
Desktop Width 1024
Desktop Height 768
Desktop BPP 32
SpeedTester
995
How the hell do I turn it off! I hate this search here now, its pretty useless but I'll look anyways.
Thanks.
Damn, I feel like such a Noob, I havnt ever messed around with powertools, is there some web site
that could give me a head start? I'm in display profiles.....advanced timing options but not sure what to do now.
Xtasy
Banned
Nov 23, 2001
568
Welcome to HELL!!!!!!!!!!!!! That's one big arse reason i like Nvidia, the Nvidia refresh rate fix for 2k n xp. I had to use entech multires for my radeon le, n even when chaging res in a game, multires still doesn't function until after i restart the game.
SpeedTester
995
Yea I know what you mean, no matter what I try 3dmark2001 results say Im still in 60hz mode.
I'm still waiting for someone to help me out.
ConFuseMe
40
I use a program called "Hz Tool" to lock my Hz rate. At least until I reformat the hard drive. :)
I'm not sure if your 3D Mark will acknowledge the change still, but it's worth a try. It works for me at least.
I can't remember where I got Hz Tool, but it's a very small progam, just do a search for it.
Also make sure you always turn V-Sync OFF before you run ANY benchmarking program.
