My new Codegen case & front fan mount
wasamicron
360
I just bought this case at a computer show. The picture doesn't do it justice, because it really is a sharp looking case. It has a high gloss metallic grey finish on metal, and a matte grey finish on plastic front. I like fact that your beige drives are hidden behind drive doors that pop open. It has a nifty way to remove top & sides. The case uses only 1 casescrew. The top slides off horizontally. After removing top, the sides slide off vertically. This case is made sturdy. Anyway, the problem that I'm having is figuring out how to mount a 80mm fan in front. There is a spot for one, but the case was made for a plastic bracket to mount the fan. Does anyone know if this bracket can be ordered anywhere?? Might have to try to mod the case to mount fan w/ screws. Of course, the case on display at the computer show had such a bracket. Also, It looks like mounting a front fan may block use of some of the 31/2" drive bays. Anyone know where I might get a thin 80mm fan?? What do u guys think of this case?? It was $46. out the door w/ a 400w power supply.
