- May 1, 2001
- 3,004
- 3
- 81
Well it maybe damaged or hopefully, just not properly mounted in the case 100% I have a Antec 1080AMG Soho Case with the included Antec True Power 430W PS. I also have a ABIT IC7 w/ Bios 1.13; P4c 2.4 NOT-Overclocked;Kingston Hyper X PC3500 512MB X2; Zalman AlCu 7000 @ 2400 Rpm 92mm Fan (This you can barely hear); A Enermax 80MM Intake fan, set to low speed, you can hear, but very, very quite; Two Rear Antec Case fans that were included 80mm connected to the 'Fan Power' plugs so they are on lower power feed to the PS. Anyway, The PS is rather LOUD in the system. It is about the same db level or a bit louder, as my old File Server, P3 based system before. This is concerning me greatly. I?m wondering if the PS has a worn Ball Bearing, or maybe damaged or something. But I can boot into windows, no Prob. and I have not had any lockups or anything.
A few things to note: The True PS seems to be 'under-volting' the Power Rails in the MB Bios. These are the #?s I got out of the BIOS screen:
CPU Core 1.48V
DDR 2.57V
AGP 1.53V
ATX +3.3 Volts 3.24V
ATX +5Volts 4.91V
ATX +12Volts 11.73V
Battery Voltage +3.3V 3.26V
Standby Voltage +5V 4.96V
Could it just be the MB Bios reporting False Voltage numbers? BUT what about my PS, does anyone think I should RMA it, or is there anyway I can ?fix? the sound problem?
Thanks
CPU Core 1.48V
DDR 2.57V
AGP 1.53V
ATX +5Volts 4.91V
ATX +12Volts 11.73V
Thanks
