My neighbor's grandaughter just asked a question
Paperdoc
2,499
374
Originally posted by: her209
Originally posted by: Bignate603
Originally posted by: MoPHo
She asked why the tires of a car (the rims, I assume) and helicopter blades look like they are moving backwards when they started moving in a forward direction. Because she's only 5, I didn't think she would be able to comprehend our brain, visual signals and the speeds at which we can take in data. So I just told her it's because of magic.
Her response was simply, "There's no such thing as magic. You lied."
My bet is she was referring to what she saw on TV. That's because of the scan rate of the TV.
LOL... are you serious?
Bignate603 is right - at least partly. The appearance of backwards rotation does NOT happen in real life observation. It is the stroboscope effect. It was noticed especially in movies which are composed of a sequence of frozen images taken at 24 (originally 16) frames per second. As a wheel turns at a particular rotational rate, its spokes pass a fixed point at a rate of (rotation rate x spokes per wheel turn). If movie frames are taken at exactly the same rate as the repeat pattern of the spokes (or some sub-harmonic of that) the spokes will appear absolutely stationary. That's because each frame is taken ONLY when the spokes are in the same place as before, but just rotated exactly one spoke further. Now if, instead, the camera frame rate is just slightly faster than the spoke repeat rate, each frame gets a picture with the spoke slightly not quite there yet, and the sequence played back appears to have the wheel spinning backwards. On the other hand, if the wheel speeds up a little and gets faster than the frame rate, it will appear to turn forward very slowly.
On TV this effect is more difficult to observe for three reasons. Firstly, no TV frame gets recorded all at once - it takes a full 60th of a second to scan half of one frame, and the wheel is actually turning during this time, so some parts of the frame are converted to an image at a different time from other parts. Secondly, interlaced scanning means that a full TV frame actually is done by scanning the scene twice: all the odd-numbered scan lines are done in 1/60th of a second, then all the even-numbered scan lines in the next 1/60th of a second. So a full frame is composed of two half-images taken 1/60th of a second apart, and the resulting picture is messed up. Thirdly, TV gets away with all this in part because the resolution of the screen is not very good, and you don't notice the blurriness of the image. But you WILL see this effect when the show on TV is a movie, because the original frames actually were frozen in time, and the broadcast process can reproduce the whole frame without movement of the wheel spokes during the scanning process.
shocksyde
5,539
Originally posted by: se7en
Originally posted by: RyanSengara
Wait what, someone beat the OP to the OP wtfffff
Not only did the 5yr old get the OP she also owned me in a sort of trickle down effect as we see here.
The time warp was because of magic, you liar.
shocksyde
5,539
Oh, and I have noticed the backwards-spinning wheels with my own eyes in real life.
RoloMather
1,598
lol
