- Feb 13, 2001
- 83,769
- 19
- 81
I posted in another thread, but thought I would share here.
Actually with three cats and two boxes and cleaning once per day each it's not bad with pine litter.
What my method is is to first tip everything to one corner of the box. Then I use a wide slotted scoop to sift out the solids. The pine dries it out well and absorbs any odors. I move everything to a 1 gallon plastic bag. Now I use the wide slot scoop to scoop up litter and try and shake out all the powder from the urine into another corner of the box. I then take the majority of the pellets left in the scoop and dump them in another corner of the box.
I repeat this until I have one pile of powder/pellets and another pile of clean pellets.
Then I switch to One of these wire strainers, I use a medium sized one that can fit inside the gallon bag. I then take scoops up from the corner of pellets/powder and sift out the urine powder.
When I am done the litter is almost perfectly clean.
About once every season I clean the boxes fully with mild bleach.
Just an FYI...a lot of friends and family I got using this method.
Å
Å
