My MCP Southbridge is HOT! Help please?
Johnbear007
4,570
Soltke NV400
My MCP southbridge is super hot, and id like to cool it but I don't want to put an adhesive on it. I'm not sure if I can fit a sink on it you can see pics at newegg website. any suggestions?
drewdogg808
1,513
if there are no mounting holes, adhesive would be the only way. unless you aim a fan over the area.
Soulkeeper
6,732
155
yeah just epoxy a small heatsink to it
i got an old 286 heatsink on mine with a small 40mm fan
the epoxy would prob be much better than the tape adhesive
Johnbear007
4,570
I imagine it would be, but I don't plan on voiding my warranty. I'll have to try tape.
