When running Vista through Bootcamp, my Macbook is getting insanely hot. I noticed the fan was turning on more often, so I finally installed Notebook Hardware Control to see what was going on. While watching a streaming copy of Lost in HD on abc.com, the fan started bellowing and the CPU temp registered 90 degrees celcius.
I've updated all my bootcamp drivers to the latest available. I'm also running into stuttering problems with the audio, actually, but I suppose that's a different problem. Again, all of this only seems to occur in Vista under bootcamp, doing the same stuff in 10.5.3 seems to run at a much more normal 65-70 degrees C.
Anyone else seen this problem, and maybe know how to fix it? I'd appreciate any advice anyone has.
edit: Uh, sorry, my Macbook's specs
2.2 GHZ C2D
2 GB RAM
Intel X3100
2.2 GHZ C2D
2 GB RAM
Intel X3100
