I have a Dell Inspiron 2650 running WinXP Pro. The card I use is a U.S. Robotics 2410 wireless PC card.
In order for the laptop to wake up properly from STANDBY mode I need to remove the card, shut down, startup, then put the laptop in STANDBY--from that poiint it will wake properly.
If i just remove the card then put it into STANDBY it will not wake up (it freezes).
If I just put it into STANDBY with the card inserted it will not wake up either (it freezes).
I have updated the card driver and have all the Windows XP Pro updates.
