my laptop isnt running at full speed? (processor)
PHiuR
9,539
I have an IBM T20 700mhz and even though in the bios i have it set to max performance / fixed max speed for processor it still runs at 453mhz instead of 699/700mhz...when i right click my computer > properties... anyone know why?
I just realized this after installing SP 2? i think. im not sure...
thanks :D
jdiddy
3,905
44
I've found that using the speed measurement from rightclicking and properties is unreliable. I've been using this program http://www.diefer.de/speedswitchxp/ for a while now and it reads cpu speed on the fly and displays it in your taskbar, along with better handling of power settings.
ShinSa
744
Your cpu probably has speed throttling, where the Cpu lowers its multiplier when the system is not in use.
This saves battery and lowers heat.
bacillus
14,517
you could also set your power scheme to desktop or "always on" for max speed full time.
