My kids computer going berserk - Help!!!
akaristos2
84
System is an Athlon based system with 128MB and AK72 Acer motherboard, several hard disks and the now infamous CDROM/DVD 220E. For starter, it never loads at the first run when turning machine on. Needs always a second boost via reset button. Secondly, now when I instruct for "Shut Down", it RESTARTs. I run scandisk several times. I was unable to re-install windows98 SE. It hangs after starting to copy files (about 15-20%). I have installed lately a 13GB Maxtor 5400rpm hard disk (E: drive). Would like to move selected directories and files to that HD including system and then proceed with formatting C: drive (About 1.5GB) and re-installing on it the OS (win98SE). What should be the process and specific steps I need to resolve these problems before my kids become so impatient. Any help, support, recommendations would be most appreciated. Thank you.:confused:
Theslowone
1,779
Two things, one is update bios, two is reinstall even if it requires a format.
To move the files you can do it from dos. say you wanted to copy something from C drive to your D drive if you start in C: you could: copy filename D:\directory you want it at.
MGMorden
3,348
Actually, if you want to move directories AND files with them then you must use xcopy instead of copy.
So if you want to copy c:\data to your e: you would type:
xcopy /e c:\data e:\
And then let it go. Please note that if you do copy files from dos then if they were created in windows w/ long filenames then you're going to get truncated names after a dos copy.
