- May 16, 2002
- 27,398
- 16,240
- 136
First, this thing is a monster ! I first used the air cooling Noctura at stock(3.4 all core turbo, 1.040 vcore), and it would keep it under 75c, OK that's reasonable. Power was right in line, about 250 watts for the CPU, in spec. So far I have not been able to get 3600 memory above 3000 on the MSI motherboard, also since I have 8 x 8 gig sticks, that may be a limiting factor.
But you all know me, I can't have stock ! So I got a custom water cooling setup with a 360x60mm radiator. Well, I wanted 4 ghz, and it will do it at 1.35 vcore, but the temps skyrocket with sustained use, and I can't have that.
So after playing around a lot, I have settled on 1.15 vcore and 3700 all core turbo@65c sustained 100%load for 64 threads and a 1080TI, It draws 600 watts from the wall, and I know the 1080TI at 100% F@H load is 250 watts, so the CPU is using about 300 watts. (50 watts for the PUMP, 7 case and rad fans, and a SSD, and NVME drive, and the motherboard). Only 50 watts over for about a 10% speed boost. I think thats a nice compromise for 100% load 24/7/365 (my cancer research for BOINC and F@H) Its currently running Linux and Win 10 in a dual-boot setup.
If you have any benchmark requests (using free downloadable software) I can do this, but I want to stick to the stable 3700 setup I have. Also, feel free to comment, but I would like objective feedback, and keep it civil.
