Sounds like you have the "smart" fan option in the BIOS turned off. It has a PWM fan so if you enable that (probably under the "PC Heath Status" category in the BIOS) there should be several settings for auto fan control. Usually its something like Turbo, Normal and Quiet.
Has it always ran at 1800rpms or is this a recent thing?
You should be able to use the Asrock Extreme Tuner in windows to alter the fan speed settings. It's not the most comprehensive program but you certainly can alter the target Fan Speed for the cpu and chassis fans.
Did you install all of your motherboard software? If not, do that. That will give you, or should give you, fan control in windows.
Asus motherboards (which is what I use) always includes comprehensive programs for CPU fan profiles and chassis fan profiles. BIOS fan profiles suck because they're harder to manipulate on the fly, obviously - so I use Asus' AI Suite software which I generally like. But just go through your motherboard DVD and see if you can locate the applicable software; i'd assume that ASrock includes this with their boards.
Seconded.
Is it a PWM fan? It should be able to control the speed, and if not then get two 1200rpm 120mm fans instead of just 1 loud 1800rpm fan, that's what I did with my Hyper 212.
Are you sure the fan type is selected as PWM, and not the other analog way?
I found it, installed it, and used it... and now HWMonitor can't detect my fan. That's a bit annoying.
The setting is in the BIOS, usually under "PC Health Status" or some-such.Since everyone is questioning this, how would i know if it's on the PWM setting? I know that it's in the correct header.
Seconded.
Also a better, quieter fan would be a good option. The Cougar PWM model is on sale for $9 @ Newegg till the end of the day.
Thirded.
I've got a 212+ and a 212 EVO--replaced the fans on both of them with Gelid Silent fans and control them with Speedfan. All is quiet.
