philip2024
I have an Internet connection with a modem connected to my Fritzbox 7530 router and a Fritxbox repeater in another room.
I have several problems that I can't quite pinpoint the cause. I have some cameras connected, no. 2 Google Speakers, an Alexa speaker, a Synology DS215J Diskstation and some connected users.
The bandwidth is ok and if I do a speed test I get approx. 150Mbs/20Mbs. The Google speakers - I don't know if it's due to the use of Alexa - no longer worked. To exclude Alexa's "interference", I turned it off and did a soft and hard reset of the Google speakers. Sometimes they work, other times they don't. If I try to reboot from the Google Home app the speakers start up (so the wifi is ok). I can also be sure that there is full wifi coverage being in an apartment of just over 60m2. In a forum, I read about disabling IPv6 from the router to solve this kind of problem, but it didn't work in my case.
With my Samsung Note 10+ phone, I have to wait much longer to receive data from certain applications than when I have a data connection. The DS215J Diskstation was configured with UPnP because I'm not very expert but it seems to work fine.
Where should we start?
