I need to get a good CPU heat sink that will keep my CPU cool, and it doesn't rattle. My last two fans would be fine for a month or two then the would rattle all the time. If anyone knows of a good fan that never rattle, I'd appreciate.
Thermalright SI-97A + 92mm Panaflo. Won't rattle; will quietly keep your precious little CPU comfortable. Deadly silent, yet has no problem whipping my 1.8ghz Athlon XP-M 2500 up to 2.5ghz.
Originally posted by: chocoruacal Thermalright SI-97A + 92mm Panaflo. Won't rattle; will quietly keep your precious little CPU comfortable. Deadly silent, yet has no problem whipping my 1.8ghz Athlon XP-M 2500 up to 2.5ghz.
