My hard drive makes my headphones make a fuzzy noise
StevenMara
Banned
May 12, 2005
429
I just bought the "Zalman Theatre 6" 5.1 channel headphones from someone on the forums. He said he only used them for an hour. He included an adapter so I could use them to play my XBOX, and they worked fine for that. Then when I plugged them into my computer, the were extremely loud (they don't have a volume knob) and I had to turn my master volume almost all the way down.
They work fine, but I can hear a fuzzy noise, and even when I turn the master volume all the way down, I can still hear it just as loud. Is it because I have onboard sound?
EDIT: Whenever my hard drive light comes on is when I hear the noise. I have an ExcelStor 80GB HDD. Any ideas?
xtknight
12,974
I used to get noise from my hard disk coming through my headphones with the sound card muted.
StevenMara
Banned
May 12, 2005
429
I just checked the hard drive thing. I started in Safe Mode and I could hardly hear the noise, then whenever the HDD light would come on, the noise would get louder. So any ideas how to fix it?
StevenMara
Banned
May 12, 2005
429
Alright, I switched IDE channels, no difference. I switched from my round cables to normal ribbon cables, and again no difference. I even used a different hard drive, and there was no difference.
I will try it on a whole different system, but I don't think I will hear it on that system. It is probably my $40 motherboard. I plugged them into my DVD player/surround system and I heard zero static or fuzz. Shouldn't an audio card work?
montag451
4,587
Please post back after you have tried them on a different system.
That is easy.
Next, try a pci sound card.
See if that does it. Remember to disable audio in BIOS before you install the new card.
StevenMara
Banned
May 12, 2005
429
I tested it on my mom's computer and she has onboard audio, but it didn't make any noise. So I ordered a cheap 5.1 channel card from Newegg.com.
