My Halo 2 case modding project.
Hey guys. I'm starting this thread to chronicle my first case modding project. I hope to update this every time I get a couple of pics to add. This case is a work in progress, and remember that it's my first one, so please suggest anything you think will improve upon the look and functionality of the case.
First, a little background of what I'm working with. For all intisive purposes, I'm using a Dremel MultiPro variable speed rotary tool. Luckily, I also work full time at a sign shop, so I have access to a CNC router, pictured here. This picture is fresh from cutting out my design, pictured later. The case I'm using is about as a generic case as you can get. I purchased it from a local dealer about 3 or 4 years ago, and it has been sitting in my closet ever since I retired it long ago. Since this is my first mod, I decided to hack this one up.
So let's get started, shall we?
First up, pictures of the case. This is case shortly after gutting it. Being my first mod and all, I forgot to take a complete before picture 🙁. And also being that I'm lazy, I wasn't about to put it back together. So, what I have is the pieces leaning where they should be 😀. These are the pieces spread out. It's not too big of a case, I know, but enough to work with.
I did run into something about this case that I didn't like. As you'll see in this pic, the power supply is in an odd position, due to the small nature of the case. If you can picture a motherboard in there, where does the PS sit? Right above the processor, which with today's technology, the heat might be unbearable for me to leave the PS where it is. What do I do?
With this being a modding project, I decided to relocate the PS. My first thought was build an acrylic enclosure, and set the PS up on top of the case. 'Tis the beauty of knowing my way around materials at a sign shop, this would've been no problem to do. However, it might look a little tacky up there, so I decided to place the PS inside the front bottom of the case. Since I'm placing it here, why not cut a window in the front bottom of the case, and light up the PS from behind a piece of clear acrylic? Here I am, set up to start cutting a hole so you can see the front the front of the case. I plan on cutting out the side of the PS so you can also see the inards lit up. I also will be putting a fan blowing out in the small acrylic window for heat issues.
Job done on cutting out a square. This is for the inside of the case, so I wasn't concerned with beauty, as it won't be seen anyway. Next up is to cut the front bezel for my window into the PS. This comes later.
Next up in the process, cutting out my Halo 2 logos in the sides of the case. This was achieved with the CNC router we have where I work. I couldn't decide how I wanted the logos, either just the logo cut out of the side? Or have a window cut out, with the Halo 2 logo reversed out, and then stuck on the window? I decided on both, that is, a window with the logo on the left side of the case, with just the logo cut out on the right side of the case. Here is the left side of the case, and you'll see my window pattern cut out. Basically, the whole side of the case is cut out, with room for the indented "handle" that is present. I then cut out the Halo 2 logo, which I will most likely cover in graphic-printed vinyl to give it a textured look, and then be attached to the acrylic window towards the end of the project. In this pic, you can see the other side, which I will be also putting clear acrylic behind. However, since on this side all you can see is the back of the motherboard tray, I will be covering the acrylic with some frosted glass vinyl, and then hopefully leading some blue (or other color) leds behind to light it up with a crystal effect.
This is all I have for now, but please make any suggestions or give me some praise if you wish 🙂.
****UPDATE 6/15/2004****
Here's a small update to my progress so far.
Pictured here is the fresh square I cut with my Dremel in the top panel of the case. The plan is to install a small, clear acrylic window with an 80mm fan for a blowhole. This pic is of the inside. This pic is of the top of the top panel. Once again, a close-up of the hole I cut.
This next pic is of the front bezel cut-out. As you read earlier, I plan on placing the power supply in the bottom front of the case, and place it so you can see the inside of it from a front window. A closer shot of the front. It's a bit rough in this pic, but I later filed it a bit more for a nicer look. Here is the fit for the power supply. The front bezel and my inside job line up pretty well. The power supply test fitted pretty good. The same pic, but from inside the case. I plan on cleaning up the cut on the inside when I get some spare time.
Next up is my paint. I've only been able to sand and lay one coat of primer so far, but I still had the scrap piece that I cut out of the side to make room for a window. I took this scrap piece and gave it a quick sanding, then a quick coat of primer, then another sanding, then a couple coats of the paint I'm using, just to get an idea of what it will look like. Here is the test subject from afar, and the color looks really good. Sorry for the blurry pic. Here is a close-up of the test paint-job, and you can clearly see where I sanded and where I didn't. Since this was scrap, I wasn't concerned with filing the edges or doing any kind of detail cleaning, so don't say anything 😉.
More updates when I can give them.
****UPDATE 6/16/2004****
Updated once again to show you guy's (and gal's) my paint job. I started by laying all my pieces out. What you see in that pic is everything after a 400 grit wetsand and one coat of primer. I'm getting ready to wetsand with 600 grit, then primer again. A close-up pic of post-primer coat #1.
Next up, we skip any pics of the second coat of primer, and go directly to all the pieces with their initial coat of Dupli-Coat Impact Blue Pearl. Purty, ain't it? Up next, a close-up of the mobo-side panel. I plan on covering up this logo with clear acrylic, then overlaying the clear acrylic with frosted vinyl, then running some green leds behind the mobo tray to light up the logo. Here is a close-up of the front bezel. It doesn't seem as if I sanded the plastic front bezel as well as I could have. Oh well. Here is the top panel, which looks very nice indeed. Here is the Halo 2 logo that will be placed in the middle of the window on the side. A picture of previously mentioned window panel. Moving on along, a look at the paint really close-up. Up next, a close-up of the recesses for the power and reset buttons. And just for the hell of it, here is the power button, which I may repaint (along with the reset) chrome. And last, but not least, the final coat on the mobo-side panel. I like the way it looks. You'll see a slight shadow on the upper left of the pic, just so you know that isn't uneven paint 😉.
Until next time.....
****UPDATE 6/17/2004****
Small update today. I got very little done, and probably will lay dormat for a couple of days due to high volume at work. If work calls, I can't do much of anything to my case 🙁.
So, to start what I did today, I got my frosted acrylic piece put into the mobo-side panel. Here is the piece of clear acrylic that I found laying around the shop. You can see the frosted vinyl I'll be applying to it in the left of that picture. And here is the frosted vinyl applied to the acrylic with no problems. I used some pressure sensitive tape we have, and here is the frosted acrylic applied to the back of the panel. A back shot of the panel.
So, after getting that in the place I wanted it, I went into the "storage" (i.e. junk) room to get a shot of what I'm looking for. With no flash, here is the panel held up to the ceiling light. You can see what effect I'm going for, although the green leds will product a little lesser effect than the bright white light. I took another with the flash, so you can see the color.
I also took a couple of pics showing the completed paint job. Pic 1 and Pic 2.
More to come probably early next week.
****UPDATE 6/21/2004****
Hey, finally got some time to work on the case today during my lunch break. I'd work on it here at home, but I live in a small apartment, and my girlfriend would kill me after about 40 seconds of dremeling through steel 🙂. So anyhow, let's get to the few pics I took today.
I tried to start fitting the power supply into the front of the case, so you can see it in all it's glory. First things first, cut the side out of it! Here it is, fearing the dremel. I took the thing apart, and bent back the piece that is to be cut off. After some fine-tuned dremeling (not really), I have success, and it's looks pretty clean. Unfortunately, I had to take the dremel to it a couple of more times, because I didn't realize that mess of wires would get in the way. Stuipd me.
So, until I have time to cut out all my windows, I put the case together with as few screws as possible to get an idea of what it looked like. Glad I did! The color is off on the front bezel! Kinda sucks, as I thought everything looked pretty even steven last week. Hopefully I don't have to buy another can of spray paint, and can even this out a little tomorrow. I'm crossing my fingers.
A pic from the side, although a little blurry. It's looking good though, I'm pleased with everything except that color difference. A front top shot of the case. You can see the color difference a little better here. Hopefully I can fix it. But other than that, the color looks great! And lastly, the back shot of the case. This is definitely my favorite pic so far, as you can see what I'm going for.
Well, in the next couple of days, I hope to get my windows cut out and applied, and will hopefully get my leds in the mail. Once I get my leds, I'll light up that logo for you guys and let you check it out. Then, this weekend, I will be heading to CompUSA and gathering up the rest of the parts I'll need to finish this thing off. Not quite sure if I'm gonna use it yet or not, though, we'll see.
****UPDATE 6/22/2004****
Small update today. Looking at this pic from yesterday, I decide to use what little paint I had left, and try to even out the color. Here is the result. Now, instead of a little lighter, it's a little darker. From another angle, it doesn't look bad at all. I think I'll leave it at that before I mess the whole thing up, and chalk it up to a lesson learned.
****UPDATE 6/25/2004****
Now we're getting somewhere! Today, I got my windows cut out for the rest of my case, and had a chance to affix the large side window with the logo.
First up today, a picture of the window, and the panel it's going on. I gave it a quarter of an inch all the way around for a flush fit. I had no problems putting the window in after using some pressure-sensitive adhesive we had laying around the shop. Remember this logo? I put some optically clear adhesive on the backside of it, and here we are ready to put on the logo. All there was to do was to get a pattern so I can put the logo on straight. The finished product!!!! The side panel looks great! I couldn't be more happy with it. Here is a back shot, as you can probably see the short amount of space I had to work with when attaching the window. This was almost a mistake, as I didn't take this into account when cutting the panel. Good thing it worked out. Another pic with the flash. It's looks just like I wanted.
A pic of both of my side panels. The windowed side will allow a visible case inside, and the mobo side panel logo will hopefully glow green (when I get my freakin' leds in, it's been a week and a half now). I hope to go tomorrow to pretty much finish all the aesthetics up, and hopefully will have all my remaining parts in early next week.
Thanks for looking!
Wow thats looking pretty nice so far. Excellent job on the side panels.
Even though its too late (and you've got a cool idea going anyways), having the power supply in the original place the case put it wasn't so bad. Almost all PSUs now come with a fan on the bottom that helps to exhaust hot air from the case. It probably would've actually helped you cool the CPU more, then again maybe not. Also it could've limited the heatsink/fan you put on the CPU. Oh and also it would've covered up like half your motherboard, so good thinking on relocating it.
This actually kinda inspires me to do a Halo mod myself. I think it'd be cool to make a case look like one of the UNSC battleships.
Yes it was definitely time to do something with your case. The fugly Metallica and PM5K stickers need to go.
I think you should put some kind of lighting on the side panel that is mostly metal so that it glows out the side of the case, possibly some ultrabright leds so it might even shine on the wall when you turn the lights off.
Hey, any specific ideas to make it more Halo-ish in mind?
Some ideas:
an LCD readout that looks like that on the assault rifle
spiky glowing things like on the Needler
Blurred that is looking great. When you get though I might have you do another case. Maybe with the theme Pistons in six........or something like that.
KD
Great job, just keep D away because he will want all the glory!!!! LOL
KD
The theme would probably have to be Pistons in 5, with a big picture of Prince just standing around on the front bezel. (inside joke)
I think it looks great. Though I think the front panel could use all the help it can get. Have you thought about adding a Crystalfontz/LCD?
I wonder if I could commission a panel or two at a local sign shop.
I think you should get like some alien action figures and put them inside your case so you can see them through the window. Make it look like they are ripping up the insides or something
Your paint job is looking nice. Are you using the same paint for the metal and plastic pieces?
I like the idea for the power supply. Since it will generate a lot of heat, maybe you will want to mod it so that it has 2 fans, one 80mm blowing from case inside to the psu fan blowing out of the case. Then block off any extra grill slots in the psu. The idea is that the air will flow through the psu and out of the case, and not rise up into the case as much.
Now that you have a big gap in the top of the case, what are you going to put up there? Water pump/radiator? a couple 92mm or 120mm fans?
This is a really nice mod. I agree with everyone on this. May be making a acrilic case in one of the 5.25 drive slots would be a perfect spot for leds and HALO figures.
I was actually thinking that exact thing on the power supply suggestion. All I would have to do is turn around the exhaust fan next to the plug-in on the PS to blow in instead of out.
Yes, I'm using the same paint for plastic and metal pieces. It actually looks pretty even across all pieces.
As for the big gap in the top of the case, I plan on affixing a clear piece of acrylic with an 80mm fan in the very middle blowing out. That way, I'll have my blowhole along with a little space all around to see down inside the case.
Sweet, man. I'm surprised there aren't more replies to this.
Well, I mean, the case is pretty standard for a mod job, but the cutout is very secksi looking. I was going to suggest some more angular holes and such (you don't have to restrict yourself to squares, and it gives your case that more of a personalized touch), but you've already done the painting and stuff, and considering you couldn't even put the case back together for a "before" shot, I doubt you're going to sand, cut, and re-paint just for a pretty hole 😛
Try to think of some other ideas you can add to it to make it have more of a "custom" look to it.
This thread is in my favorites, btw. 🙂
yeah that would be great. Also you should put some leds or other lights in the psu or inside the fans. it would add a cool flashing light thing to that area of the case. maybe blue, since that is the color of your case, would be a good choice.
I actually was going to light up the power supply in the front. I may go with a green, since that's what I'm shooting for as far as lighting goes.
The blue color makes me think Covenant when considering the Halo universe. In that respect, a purple or pink lighting color would go along with it more. I like green more myself, but if you want it to coordinate with your subject the other two would do so better I think.
I doubt you'd go for pink in any case, but thought I'd mention it. If you pay for shipping I've got two pink CCFLs with inverter that I'll give you. It was supposed to be red, but it is pink instead and I don't have them on for this reason.
Thanks for the info on a suggestion of color. Actually, purple is a great suggestion that I had not heard yet. Green was the only logical color that I tried to fit within the Halo universe, and as such, have already ordered the leds. The great thing about leds, though, is that they do not cost much, so my options are still open as I haven't gotten any CCFLs yet. Thanks for the offer of the pink CCFLs, but I'll pass. 🙂
Hey blurredvision. any new pics to post? 🙂 I'd like to see how your mod is going.
Ask and you shall receive 🙂. Thanks for the interest. I've got some new pics up, hope you guys like how it's coming along.
The paint looks funny because the front panel is plastic, and the rest is metal. You probably realized that already though... I've had the same problem before when painting cases. It sucks. I think the only way around it would be to intentionally make the front plastic piece a different color.
I think the case looks good put together, but the silver back and insides is bothering me. Have you thought about painting the insides? Some solid color, maybe a dark blue, would look nice. At least I think so. 🙂
