I have PIV 1.6a overclocked to 133FSB, 2.13 GHz, at 1.6 Vcore. Using Thermaltake Dragon 478 heatsink/fan, with Artic Silver 3, and the fan controller setting set at low (around 3800-4000 rpm, i think).
I have VisionTek Geforce 3 Ti/200, overclocked to 220MHz/500MHz using the registry heck, (don't know if this is actually heck, but using a file that I downloaded from HardOCP, puts an option in the display setting's where I can change the frequency of core and ram). Just changed the stock heatsink fan to the Thermaltake Crystal Orb, again using Artic Silver 3.
I have MSI 645 Ultra board, which apparently has temperature sensors that do not work. So I have two CompuNurse temperature monitor probe. One I attached right next to the CPU under the heatsink, not between the heatsink and CPU, but right next to it so it will touch the CPU core. I have the other probe on the back side of my video card, around the area where the GPU lies.
Right now, I am surfing the web, so not much load. The temperatures read 37.4 C for the one attached to video card, and 30.4 C for the CPU.
Is this normal?? If I put some load, like play CS or run PCMark2001, the CPU will rise to around 38-40 C, and the GPU will rise to about 41.8 C.
I just think that the CPU temperature should be much higher, but i could be wrong.......
Sorry for the long post, but I didn't wanna leave anything out.
Thanks,
Slim
Thanks,
Slim
