My garage project - pretty much done - video of mostly completed project
DrPizza
Pretty much done as of 2 weeks ago; been busy catching up with everything else. Here's a quick video of the final results. Yes, I shot horizontal first, but it doesn't look as good as vertical. Apologies.
https://www.youtube.com/watch?v=v95oMQ-dj24
Getting close to done; wife is mortaring in the electric radiant floor heating in the bathroom as I type this. Got the type with the mesh backing - almost a skim coat, pressing just the mesh into it with a narrow putty knife, and will floor leveling compound it after it's dried a bit.
Shower walls (the protective plastic is style on the base - 38" base):
What does "My garage project" mean ?
Does it mean a sort of side hobby activity, making useful stuff or something (especially on Sundays) ?
Turning the garage into an apartment. My mother is older, retired, and wants to move back to NY. Figure it's the simplest solution for her. Roughly, 13x15 living room, 8x15 kitchen/entryway, 12x12 bedroom, 2x8 closet, 7x12 bathroom.
I'd probably call it a major project, since I've done everything with a little help from my wife - concrete work, framing walls, cinderblock wall, all the plumbing, electric, gas lines, drywall, flooring, ceiling, etc. Basically, everything other than the shell of the garage - I've even re-roofed it. Bro-in-law helped with the plumbing a bit, roughing in the dwv, but other than the kitchen sink drain, and where it ties into the septic line, I've had to redo all of it, since the design changed slightly, leaving the rough-ins in the wrong locations - plus he forgot to rough in for the bathroom sink.
Thanks for the helpful, reply, explaining what you meant.
We call them "Granny Flats" in the UK.
Wow. So you are practically building a tiny house, all by yourself (+wife).
(Speaking from across the pond) Something about American culture, seems to give people the confidence, incentive, push, equipment etc to do things like that, themselves.
Which has got many good things about it. It is probably a significant factor, in some of the (eventually to become) massive, global companies, such as Apple. Which itself, was suppose to have started up in a domestic garage.
In the UK. Most people would NOT do stuff like that themselves. So it either would NOT get done (too expensive to get companies or builders to do it), or it would be built by a builder or building company.
There are some people in the UK (who are NOT professional builders or anything). Who do stuff like that, themselves.
Also in the UK, things are more formal (my impression). With much more red tape. Because stuff like that, may need to get planning permission, from the local council. Because of the change of use of a room(s). creation of a new dwelling, and various building/electrical inspections would be required. (I'm NOT too knowledgeable about planning or building regulations. But I think I am giving you the gist, of the situation).
Fixing a broken toilet, is probably the limit of my current DIY, experience/ability/confidence level. Even then, I managed to partly soak the carpet. Because there was a tiny (I thought) amount of water left in it, when I was changing the float mechanism.
Which decided to gush out, after I had removed the lower pipe.
I suppose if I helped someone who was very knowledgeable about stuff like that, do it. I would soon learn the ropes, and be able to tackle stuff like that, much more so, myself.
In the UK, it is now against the law, for non-electrician people, to add to the electrical systems in their homes. (Mainly on safety grounds).
E.g. Wire in a new mains socket.
Repairing existing systems, is allowed. E.g. renewing a bust mains socket.
I think, you can do a lot of electrical work. As long as, BEFORE you connect it up for real, a qualified electrician checks/inspects that it has been done correctly/safely/to-the-electrical-codes.
Some people enjoy stuff like that. I would prefer to be at my computer, or doing something else. But I can understand why people like stuff like that.
Looks like you're using a curved rolling door?
What am I seeing at the bottom left of the shower pan? It looks like you notched out the tile.
Great looking job.
Yep, rolling curved door. Updated OP with new picture. I have to apply silicone to it tomorrow - letting my wife clean the surfaces first. Then, there are a few places, such as the bottom of the tile, where I'll hit it with a caulk that matches the grout. Grout is already sealed.
In other areas, I finished drywalling around the breaker panel and doorway - a small area that I left undone so I could add electrical circuits up to the last minute. High humidity = it's drying very slowly. 24 hours since coat 2, and it's still just a little damp; waiting til morning for the final coat of mud.
Tomorrow: bedroom carpet goes in, and molding along the floor. Pad and tack strips are already in. Tile floor goes into bathroom. 20ish feet of crown molding in the living room to finish; been blowing that off for weeks. And finally hook up the 100 amp service in the basement. And maybe tomorrow night, priming the last 40 square feet of drywall. Closet organizer, blinds in the windows, then start organizing the tools and hauling them out of here. I must have a few hundred tools out here.
Monday, grout floor in bathroom, finish painting
Tuesday: install vanity/sink, toilet, mirror.
And I think... I'll be done.
It's coming along nicely.
I love the attention to details (from looking at the updated pictures).
Even your soda cans, are highly color coordinated with the ladders, label on its side. (Joke).
You seem to be finishing this project, nice and quickly.
Nice looking shower Doc, and good on ya for making mom a space near you. That indeed is a huge job. It is a whole apartment build, all the garage provided was a roof and 4 walls. As I recall you even had to fix/level the floor.
And, since the walls were built on cinder blocks, I ended up building a second wall on top of them, giving me an 8" thick wall (and lots more insulation). So, the garage provided a roof and 1 1/2 walls. Oh wait - I replaced the roofing last November. 😛
Leveling the floor turned out to be pretty easy. Or rather, getting the floor "good enough" was easy. Carpeted area, I didn't care if it wasn't perfect. Bathroom - got it pretty good, and used a few bags of self-leveling compound just prior to tiling it. Wife has been doing the tile, except cutting curves (toilet, shower base) - using that sort of wood-grain 23"x5" tiles. Got ahead on the painting - just need a few touch-ups. I managed to get away with 2 coats of mud, and just a few very minor touch-ups which dried quickly with a fan on them. I still see a couple of flaws around a door - expected the trim to cover them, but I misjudged the width of the trim, so I'll have to do a little touching up. Didn't manage to get the 100amp hooked up; started to, but got distracted. Happy that the ohms on the radiant floor heat still check out now that the flooring is on top of it - I was a bit paranoid after reading the directions that told me to keep checking it.
Closet:
I still have to finish off the carpet by the bathroom door, and a few pieces of baseboard, but I know that if I finish it now, I'll end up having to either do a 1" row of tile, else have to cut off 1" of tile. I'll happily adjust the length of the carpet instead. Baseboard is a pain in the neck - fastening through the drywall into concrete blocks.
I could make a list of all the little things I did, but suffice to say, boy did I underestimate the amount of individual little tasks to complete this job. I found it greatly enjoyable and only went over the budget for the project by... a lot. E.g., ran to town to get a couple pieces to hook up the propane for the stove (hook up to the propane tank outside) - black pipe tee, nipple, 1/2" male adapter for the gastite, I was low on thread sealant and teflon (yellow) tape, so picked those up too, just to make sure I didn't run out after doing one fitting, and grabbed a tubing cutter, since I can't remember which tool box I put mine into. Bam. Forty bucks.
Should be fixed now - it did one of those "will be processed later" things, then I needed to refresh the publish.
That's a pretty good job! It's always hard to tell with just a video, but it looks pretty pro to me. It makes me wonder... if you needed to learn how to do some sort of project, where did you usually go to get more information about it?
Usually, I watched a video or two on youtube for help/ideas about part of the project. There are times this made a huge difference, or at least put my mind at ease about tasks I had never done before. E.g., self-leveling compound over a concrete floor, or installing the electric radiant floor heating. Or, "oh crap." <video> "Oh, so that's how you disconnect a sharkbite fitting. That's easy enough." I had never done a cinder block wall before. I watched a few videos; one of them had Bob Vila demonstrating on a job project, but the others had seasoned professionals doing it. I was better than Bob on my first block, and by the time I was on the 4th or 5th block, at least in my mind, I think someone would mistake me for someone who had been doing that as a job under professional guidance for at least a few months. But, the most important information I found and really understood: use the right tools. Better tools make a job easier. The first ceiling part that I did - a chop saw on the floor. By the time I got to the closet ceiling, I was using a much better quality compound miter saw, on a stand, with stops set so that I could rapidly cut all my pieces to length. One of my son's thought I'd give the chop saw as a hand-me-down. I felt greedy and said, "I'll still need it for small projects." I've spent enough time on the bigger saw that it's worth it to drag that thing out (it has wheels) instead of just carrying the smaller one. I'm saying good-bye to my radial arm saw as well in this process.
