My front antec fan is going crazy
ManBearPig
9,173
My front antec 120mm led free ball bearing fan is making crazy ass noises. Whats going on?
Is the fan dead, as in the ball bearing are not functioning properly? Or is it dirty? Thanks
The Pentium Guy
4,327
Once ball bearing fans get old, they start making noises.
Try cleaning it out though.
I heard that sleeve bearing fans quietly(this is bad, in a way, because you won't know if it's dead or not), and ball bearing fans do the opposite.
How old's the fan?
-TPG
IntegraGSR
246
it may be dirty.. dust buildups can cause a fan to make noise due to uneven weight distrobution
