My friend's sub box is done! (2 12inch Peerless XLS subs)
Viperoni
11,084
a couple of pics here:
Front and back of box pics
I finally got some time to listen to them.
They're more than loud enough (probably hitting 130db), and they hit hard, and clean. He's really happy, but I don't think his neighbours will be :Q
Viperoni
11,084
<< Nice work, it looks GREAT! :Q >>
Sucks he ran out of paint in the middle of painint the port :(
Sorry for the crappy pics too, my kodak dc120 is showing it's age :Q
Viperoni
11,084
<< do you really need speakers like that in a car. its a bit much dont you think? >>
Definetely, I agree it's overkill. A single of those 12's in a sealed box would have been plenty for average listening. But if you wanna be heard a long ways away...... :D :D
Koing
Elite Member <br> Super Moderator<br> Health and F
Oct 11, 2000
16,843
looks good!
Job well done;) now do it in my car.....
stev0
5,132
130 db... i think not.
edit: speaker wire is also overkill, maybe even your power (hard to tell from the pic) Not trying to crap in your thread but I'm just saying... maybe for future reference when installing systems into cars. Your whole care is wired with nothing greater than 16 guage wire, except for things around the alternator and the batterie cables. I could see a thicker gauge wire being used for amp power and ground, but it doesn't need to be anything ridiclously large. (spelling... i need to work on it)
Lithium381
12,452
I think it looks sweet, i'm thinking of adding two 10's to my truck....heh, won't turn out as nice as that, your friend did some sweet work
vip - YHPM
N8Magic
11,624
<< Bump for the bassers :D >>
Don't they usually call them type of fishermen Bassmasters? :D
Viperoni
11,084
<< 130 db... i think not.
130db, you don't think so? It's pretty close if not. They do have a slight rise of about 2db in the 60hz region, so if it were to go throgh an all-out SPL scenario, it probably would come damm close to 130db.
Definetely overkill, but it looks nice.
Power wire's 4g, all the way from the battery clamp, to the underhood fuse, to the amp. The remote wires an 18g, and the 4-5foot ground is only 10g. Like you said, you don't need any thicker :)
<< I think it looks sweet, i'm thinking of adding two 10's to my truck....heh, won't turn out as nice as that, your friend did some sweet work >>
It was the both of us installing the amp, building the box, I did the box planning, he basically did all the dirty work. Hey, it is HIS system afterall :p
<< Don't they usually call them type of fishermen Bassmasters? >>
Bassmaster's is reserved for the 140db crowd ;) Soon nate, soon :D
