WoodButcher
After seeing the threads here on TECs I decided to finish this project. Here is the thread I created on XS, I took a year and a half to finally complete but it was a learning experience. Tecs are not somethig I would consider for any 24/7 application but I did run this setup for the past week so I thought I'd share.
Here are most of the pics but for more detailed explanation and final conclusion you'll need to visit the original thread,
Thermal Enterprises model CP1-12726
50mm x 50mm x 3.64mm
Maximum power consumption 400 Watts
Operates from 0-15.4 volts DC and 0-26 amps
Operates from -60 deg C to +180 deg C
Each device is fully inspected and tested Fitted with 6-inch insulated leads Perimeter sealed for moisture protection
and these,
INTEL XEON
Socket 771
QUAD-CORE 5400 SER. 3U ACTIVE/(1U Passive) FAN AND HEATSINK
and these are what resulted,
my "nightstand" don't mind the carpet, We had a little flood recently,,,
top removed
side open
back, tecs installed
and my thermo control unit.
and these,
INTEL XEON
Socket 771
top removed
side open
