- Feb 15, 2003
- 44
- 0
- 0
hi,
i have the following in my newegg basket right now ... although i have selected the RAM here as well I would welcome other selections for RAM .. this PC will be used mostly for gaming/work and I will be overclocking... here are the parts i have so far.. I also needs suggestions for a heatsink that will fit on the abit nf7-s mobo and also a fan to go along with the heatsink and thermal paste... thanks
ases (Computer Cases, ATX Form)
ANTEC Performance Plus Case with 430W Power Supply, Model "PLUS1080AMG" -RETAIL
Specifications:
Case Type: SOHO File Server
Color: Antec Metalic Gray
Material: 1mm SECC Steel
Drive Bays: 5.25" x 4/0, 3.5" x 2/4 (external/internal)
Expansion Slots: 7
Front Ports: 2xUSB & 1xIEEE1394
Power Supply: 430W
Cooling System: 3x80mm installed Fans
Mainboard Compatibility: up to Extended ATX
Dimensions: 20.6"x8.1"x18.6" more info>
N82E16811129115
$110.00
$110.00
Memory (System Memory)
Mushkin 184 Pin 512MB DDR PC-3200 - Retail
Specifications:
Manufacturer: Mushkin
Speed: DDR400(PC3200)
Type: 184 Pin DDR SDRAM
Error Checking: Non-ECC
Registered/Unbuffered: Unbuffered
Cas Latency: 2.5-4-4
Support Voltage: 2.6V
Bandwidth: 3.2GB/s
Organization: 64M x 64 -Bit
Warranty: Lifetime more info>
N82E16820146219
$87.00
$87.00
Motherboards - AMD
**This item is NOT REFUNDABLE, exchange for same exact item only!!**
ABIT "NF7-S" nForce2 Chipset Motherboard for AMD Socket A CPU -RETAIL
Specifications:
Supported CPU: AMD Duron/Athlon/Athlon XP Processors
Chipset: NVIDIA nForce2 SPP + MCP-T
FSB: 400/333/266MHz
RAM: 3x DIMM for DDR333/266 Max 3GB, 2x DIMM for DDR400 Max 2GB
IDE: 2x ATA 133 up to 4 Devices
Slots: 1x AGP 8X/4X, 5x PCI
Ports: 2xPS/2,2xCOM,1xLPT,SPDIF Out,6xUSB2.0(Rear 2),1xLAN,Audio Ports
Onboard Audio: nVIDIA SoundStorm APU(Dolby 5.1) + 6-Channel AC97 CODEC
Onboard LAN: 10/100Mbps Fast Ethernet
Onboard SATA/RAID: 2x Serial ATA, RAID 0/1
Onboard 1394: 2 Ports
Form Factor: ATX more info>
N82E16813127166
$86.00
$86.00
Processors
AMD 45 Watt Mobile Athlon XP 2600+, 266 MHz FSB, 512K L2 Cache Processor - OEM
Specifications:
Model: AMD Mobile Athlon XP
Core: Barton
Operating Frequency: 2GHz
FSB: 266MHz
Cache: L1/64K+64K; L2/ 512KB
Voltage: 1.45V
Process: 0.13Micron
Socket: Socket A
Multimedia Instruction: MMX, SSE, 3DNOW!, 3DNOW!+
Packaging: OEM(Processor Only) more info>
N82E16819103436
$99.00
$99.00
Video Cards
SAPPHIRE ATI RADEON 9800 PRO Video Card, 128MB DDR, 256-bit, DVI/TV-Out, 8X AGP -BULK
Specifications:
Chipset/Core Speed: ATI RADEON 9800 PRO/380MHz
Memory/Effective Speed: 128MB DDR/680MHz
BUS: AGP 8X
Ports: VGA Out(15 Pin D-Sub)+TV-Out(S-Video Out)+DVI Connector
Support 3D API: DirectX®9, OpenGL®2.0
Cable/Accessories: 4 Cables, VGA via DVI Adapter, PowerDVD, Driver CD
Max Resolution@32bit Color: 2048X1536@85Hz more info>
N82E16814102268
$207.00
$207.00
Subtotal »
$ 589.00
Specifications:
Expansion Slots: 7
Power Supply: 430W
N82E16811129115
$110.00
$110.00
Specifications:
Bandwidth: 3.2GB/s
N82E16820146219
$87.00
$87.00
Motherboards - AMD
Specifications:
FSB: 400/333/266MHz
N82E16813127166
$86.00
$86.00
Processors
Specifications:
Core: Barton
FSB: 266MHz
Voltage: 1.45V
Process: 0.13Micron
Socket: Socket A
N82E16819103436
$99.00
$99.00
Video Cards
Specifications:
BUS: AGP 8X
N82E16814102268
$207.00
$207.00
Subtotal »
$ 589.00
