Well I finally OC'ed my system. Not too much since I don't trust my PSU and and the Stock HSF too much (Antec 350W). But with a Athlon 64 3000+ I was able too get it very stable at 2205 MHZ from its stock 1800 MHZ.
I set the HT x4 (978) and the FSB/HTT 245, running my Kingston ValueRAM at 166 in the bios while they are actually running at 200Mhz and with 1T and faster timings ie: 2.5-3-3-7 which is nice. EVEREST which I use to get info has it running at 33c idle and 47-50c full load which I think is exceptable. It also says my 3000+ is a 3500+ which is kinda amusing. I'm at 9x244
All in all Im pretty amused that I pulled this off without blowing my system up
Now all I have to do is keep it in one together, I think I am going to run Prime95 tonight and see if my computer's still alive in the morning. Does anyone know a which setting to use in the Torture test? Should I use the Blend one or In-Palce test.
Also runnig the Ram at the lower timing's won't hurt it will it? or should I manually set it to the 200Mhz settings?
