WOW! Cooling way way better than Antec P180 and way way quieter. This case is going to be my forever case. Wire management is way better than P180 and clean looking; no more spaghetti mess.
I have one grip about this case. The EVGA 680i SLI motherboard I/O backplate is not compatible with the case. I don't know if it is Zalman or EVGA fault; the I/O backplate just doesn't line up. Now I am running my system without the I/O backplate. Is there any harm/hazard running the system without one? I think the I/O backplate is for safety and EMI shielding -- would this be harmful to human? I know one hazard is that I won't be putting my fingers near there with all the capacitors exposed.
Specs:
Cooler: Ultra ChillTec w/92mm 1600RPM for the cold heatsink, 92mm at 1200RPM on the hot sink.
Q6600 @ stock
EVGA 680i SLI
Patriot 6400 LLK @1200Mhz
Corsair HX620W
RAID 0
Thermal Performance (P180 had Pentium D 945 @stock):
CPU: idle @ 23C; normal @ 25-27C; load @ TBA
(P180: idle @28C; normal @ 30-31C; load @ 45C)
SYSTEM: idle @ 31C; load @ TBA
(P180: idle @ 37C; load @39C)
GPU: 8800GTX idle @ 58C
(P180: 8800GTX idle @ 66C)
Noise Performance:
No instrument to measure it, but it seems very quiet I would say 5x better than P180 (P180 with all Antec standard fan on low)
Specs:
Q6600 @ stock
EVGA 680i SLI
Corsair HX620W
RAID 0
Noise Performance:
