My first ever build!! :-)
shabz
This is my first ever attempt at building a PC, so be nice :)
Requirements
- Internet
- Word processing
- DSLR photo editing in Photoshop
- Dreamweaver
- Creating graphic in Photoshop
- Needs 5.1 support to supply my Logitech Z5500s with crisp sound
- Games (FPS eg. COD4/WOW, strategy eg. C&C Tiberium Wars, and racing games for my G25 eg. Grid, GTR2 etc)
- Digitalising tapes with my Hauppage card...this has hardware encoding
- Obviously loads of misc stuff but this is all I could think of
- I want it to last 5 years - not fussed if I can't play the latest games in 5 years
Proposed Spec
CPU - Intel Core 2 Quad Pro Q6600 (clock to 3.0Ghz)
CPU Cooler - Arctic Cooling AC-FRZ-7P Freezer 7 Pro Socket 775
GPU - Asus HD 4870 1GB
RAM - not sure?
HDD - Samsung SpinPoint F1 HD103UJ 1TB Hard Drive SATAII *32MB Cache*
DVD - Pioneer DVR-216DBK 20x DVD±RW Dual Layer Internal SATA
PSU/Case - Coolermaster Elite 330 Black Case With CM eXtreme Power 650W PSU
Motherboard - Asus P5Q-E P45 Socket 775 8 channel audio ATX Motherboard
Monitor - Samsung SM2433BW 24" TFT Monitor 1920x1200 20000:1 300cd/m2 5ms VGA/DVI
so how does it look? will everything integrate together ok?
still unsure on ram...can't be OCZ as it may not work with asus motherboard...cpu will be clocked to around 3.0ghz...which of these are good?
http://www.ebuyer.com/product/130429
http://www.ebuyer.com/product/140132
http://www.ebuyer.com/product/153130
TridenT
16,800
45
What is your budget? What is the maximum you will spend? Where are you located?
Also, get a nvidia card.
yh125d
6,886
Don't expect that system to last anywhere near 5 years. Nothing does
shabz
my last desktop lasted 7 years before i decided it was too slow...in that time i had 1 hard drive failure and that was all...a desktop should easily last 5 years...i'm not fussed if i can't play the latest games in 5 years time
the q9400 puts me over my budget...
am happy with the hd 4870 1gb as the gfx card, very good value for money
have also chosen the ram now...
only thing i'm concerned about...is the coolermaster PSU up to the job?
shabz
the budget was £70 for psu and case...which is around $100? not sure on the relative price of pc components over there in the states
heyheybooboo
6,278
Don't know if you are interested but it looks like from ebuyer you may purchase the MSI KA790GX with a Phenom II 940 for less cost than your P5Q-E/Q6600 combo.
The downside is that it looks to be the only 790gx/sb750 mobo I've seen that does not have Crossfire - but it is already qualified for a AM3 cpu ...
nineball9
789
Some reviewers on NewEgg have noted that the AC Freezer 7 will not fit that mobo unless you bend some heat sink fins. You may want to research it a bit.
shabz
Googling brings up people having issues with the Asus P5Q Pro with the AC Freezer 7...I've ordered the P5Q-E...any info on this?
bit late as i've ordered the cooler, could always exchange it
Blain
Originally posted by: shabz
Requirements
- Dreamweaver
betasub
2,677
Budget, budget, budget.
Yes, you'd get a lot more help. ATer's can even price up a build in UK£.
TestSpecimen
32
I didn't experience any problems installing a Freezer 7 Pro on the P5Q Pro build I put together a couple weeks ago. Don't know what issues other people could be having.
