My first DIY headphone amp - a Cmoy.
imported_amx
490
Finally i finished building my cmoy. It took me a couple of good hours on saturday and sunday to complete it. It was lot of fun soldering, cutting and doing all sort of fun stuff.
Here are some pics:
http://www.flickr.com/photos/amx/sets/110675/
It certainly give steroids to your headphones or earlugs. Even cheap headphones sounds pretty good with an amp. If you want to dive into DIY electoronics and pc bords, its a great first time DIY project. I definately learned a lot about circuits even though i took an electronic class in high school.
Enjoy:)
Akshay
Edit: I posted where i found the instructions below. Yeap its a altoids tin :) with silver primer spray pain;)
Specop 007
9,454
I've been thinking of doing one of those. The pre builts cost an arm and a leg compared to a DIY version. Just havent gotten around to it. What amp chip did you use?
imported_amx
490
Yea prebuilt cost a ton. I used a dual-op amp(OPA2132P). I think its made by TI. Bought most of the parts of Newark and radioshack. Tangent has a parts list.
Specop 007
9,454
I didnt know if you used the recommended amp chip or an upgraded one. I had looked into a few other models with L/R outputs, and also looked at bridging outputs for more oomph.
Cant remember which ones I was looking at right off though.
imported_amx
490
I really didnt want too much experiment on my first try, but next time i build one i will:)
I did change the layout of the components.
Yea i think i am definately going to build more complex ones in future.
Specop 007
9,454
Look into some high ends caps or something. Go all out. I've heard good things about the Hovland Musicaps, but they run a pretty petty. Solen is supposed to be good too, for both caps and inductors.
pennylane
6,077
Originally posted by: Zanix
How long do the batteries last?
A good 9V should go for about 40-50 hours I think. I'm in the process of making one but I've had some... holdups.
Zanix
5,568
12
Holdups, as in dry martinis? ;)
So if you wired them in a series and hooked two together then you could get like half a week?
Zanix
5,568
12
mine is wierd in series. Im putting in roughly 18v into the amp which is 9v per channel.
So have you had to change the batteries yet?
imported_KirbsAw
1,472
Man I really want to make one of these, but i've never made anything like that before, i don't think it would work when i was finished.
Specop 007
9,454
One way to find out. Its like 40 bucks in parts man, your not gonna be out much if it doesnt work.
