- Jul 7, 2007
- 41
- 0
- 0
Hello everyone. I'm building my first gaming rig, and I need some advice and feedback.
1. What YOUR PC will be used for. That means what types of tasks you'll be performing.
Some CAD design, gaming (Skyrim!), video editing later on
2. What YOUR budget is. A price range is acceptable as long as it's not more than a 20% spread
$1000-$1200
3. What country YOU will be buying YOUR parts from.
US
4. IF YOU have a brand preference. That means, are you an Intel-Fanboy, AMD-Fanboy, ATI-Fanboy, nVidia-Fanboy, Seagate-Fanboy, WD-Fanboy, etc.
None, though I believe Intel is kicking AMD's ass and AMD is kicking NVIDIA's
5. If YOU intend on using any of YOUR current parts, and if so, what those parts are.
None, I have no parts
6. IF YOU have searched and/or read similar threads.
Not on this forum
7. IF YOU plan on overclocking or run the system at default speeds.
Most likely OC the processor
8. What resolution YOU plan on gaming with.
1920x1080
9. WHEN do you plan to build it?
By beginning of December. I may hold out on buying some parts until Black Friday, though I have not seen a trend in prices just yet.
10. Don't ask for a build configuration critique or rating if you are thin skinned.
OK.
Well, so far I've done decent amount of research on components and on prices. First, I begin with the items I've already bought:
CASE - $75 - CORSAIR 400R (from NCIX US)
CPU COOLER - $22 - CORSAIR A70 (from Amazon)
GPU - $200 - HIS RADEON 6970 (from Amazon)
And now onto a few other parts that I've seen and believe have good price performance.
MOBO - $120 - Biostar TZ68A+RCH
CPU - $200 - i5-2500k
RAM - $40 - Any 8-16gb 1600MHz that runs @ 1.5V
MONITOR + PERIPHERALS - $150
OPTICAL - $50 - BD+DVD+CD RW Combo drive
HDD - $50 - Doesn't really matter
SSD - $110-$150 - Waiting on reviews of OCZ Octane
And the part where I'm having the most issue
PSU - $80? - 750W
So the conservative price tag (with these prices) is $1100. I have an MX 118 mouse that I may use, though I'd much prefer to get a wireless gaming mouse and I'd also like a headset, but maybe I'll snag those on BF under a different budget.
There are two things that I've found particularly hard: selecting a good PSU and whether I'm skimping on the Mobo. As for the Mobo, it has great reviews on Newegg and I've seen some excellent reviews on it. Any clue on whether it will perform with the overclocking, and what's the highest that I could go with it? (I wouldn't want to go above 5GHz in any case). Also, what's the difference between TZ68A+ and TZ68A+RCH?
I don't believe I'll be OC'ing the GPU, as it's a pretty high end card and I hear it runs hot. Any advice on keeping it cool?
And then there's the issue of the PSU. It's my first time building a system and I have no clue how to estimate the power draw. What I do know is that I would like a PSU that will last me a good few years -- it seems that a lot of manufacturers make PSUs that will burn, have high incidence of DOA, etc. I'm willing to go at some premium for quality.
Again, your feedback and help is appreciated
$1000-$1200
US
Not on this forum
1920x1080
OK.
PSU - $80? - 750W
