This is my first time building my own computer and so far this is what I got...
AMD Athlon 3400 CPU
NEC DVD-R +/- Double Layer
Maxtor 250GB SATA HD
Kingston Memory (3ct-512 DDR 400)
DFI Lanparty UT neForce 3 250GB Socket 754 ATX MotherBoard
and still have to get a monitor, keyboard, and Videocard
My question is: Is it worth it to keep 3 DDR400 memory (1.5GB) in the three slots of the MoBo and will the MoBo handle the 1.5GB DDR RAM??? Or should I just return one and just keep 1GB RAM? Also, which video card do you recommend, ATI or nVidia? I was going to go with the ATI, but I noticed that some of the X-series are PCI Express. I was wondering if they do make an ATI X-series 8X/16X AGP, is that a good choice? Also, which keyboards and monitors do you recommend. Thanks...
AMD Athlon 3400 CPU
