My first build:
  • Thread starter Thread starter
  • Start date Start date
Yo, I'm new to forum so I just wanted to drop by and say hey.
This is my first build:
Thermaltake XASER III Case V2000A
MSI MB K8N NEO2 PLATINUM
AMD Athlon 64 FX-53, 1MB L2 Cache, 939 Pin
ZALMAN CNPS7000B-Cu Copper CPU Cooler
OCZ EL Platinum Revision 2 Dual Channel Kit 1GB(512MBx2) DDR PC-3200
OCZ DDR Volt Booster
Lite-On 16X DVD Dual Drive, Model SOHW-1633S Black
Lite-On Black 52X32X52X16 Combo Drive, Model SOHC-5235K BLACK
Creative Labs Sound Blaster Audigy2 ZS Platinum PCI Sound CARD
2 - Western Digital Raptors 74GB 10,000RPM SATA Hard Drive 8MB in Raid "0"
Maxtor Ultra Series Kit 200GB 7200RPM SATA Hard Drive
eVGA nVIDIA GeForce 6800 Ultra Video Card
OCZ PowerStream 520W Power Supply With Adjustable
Power Rails With LED Indicators, SATA Connectors
IN-WIN 7-in-1 USB Card Reader BLACK
I/O Magic 1.44MB 3.5 Inch Internal Floppy Drive, Black Bezel
Added: Two Blue LED Fans
A green light that pulses to the bass
A liquid Blue Neon Lght
Existing Equipment:
Dell Trinitron 19" CRT
Deskjest 970 Cxi Printer
Logitech Freedom 2.4 Cordless Joystick
Logitech wireless keyboard and mouse
HP scanner5100c
I just finished it tonight will power up soon.
Existing Equipment:
HP scanner5100c
WOW! nise! Just a footnote here. I'd wished I had gone with higher rated speed RAM for my Winny setup. These chips are so easily oc'd I didnt think ahead of time and get pc3700/4000/4400 RAM. I have corsair 3200XL which is NISE but holds me back as far as oc'ing the FSB/CPU. If you are wanting to do some high oc's save youself some time and get some pc 4000/or 4400 so you can run a 1:1 FSB/RAM ratio and max you sys out! Save your $ and do this plz if you are an oc'er! I am not totally familiar with the MSI mobo so there are other variables here 😉 g-Luck
Existing Equipment:
HP scanner5100c
jus thought i'd pipe in my 2 cents worth. i'd save a few bucks and not get the extra cd burner i have that dual dvd burner and it does great even on cds- looks great to me i jus might go w/ a different case you should check out lian-li cases
