pokerdoc123
This is going to be a computer used almost exclusive for multitabling online poker sites. When I play, I usually have about 10 tables open at a time along w/a stats program that constantly imports hand histories, and anohter one that puts up an overlay to display them. I will also be running a virus scan, internet explorer on occasion, aim on occasion, and itunes. I will not be doing much gameing so I don't need any high end audio or video. The only real video issue might be that I need to hook up dual monitors w/1600x1200 resolution (Dell 2001FP). I'm also trying to get this computer built for less than $1000. This computer has to last for at least 5 years and I don't plan on overclocking it at all. Now that you know what I'm going to use it for, heres the specs.
AMD Athlon X2 4200+ - $362 I feel the dual processor is important since I will be doing a lot of multi task.
ASUS A8R-MVP Socket 939 ATI Radeon XPRESS 200 CrossFire ATX AMD CrossFire Motherboard - $97 I really have no clue about motherboards but a friend of mine who builds comps recommended this one to me for use w/the chip
Raptor 74g 10k rpm harddrive - $100 don't think I need more than room than this as I don't be dowloading many videos and only have ~2 gigs worth of music
Antec Sonata II case - $100 I read good things about this case. Seems simple w/ample power, I like the look and many people have said the case is really quiet which I like too
CORSAIR ValueSelect 1GB 184-Pin DDR SDRAM Unbuffered DDR 400 (PC 3200) System Memory - $77 Seems like good ram to go with, many good reviews
PNY VCGFX55PPB Geforce FX5500 128MB 128-bit DDR PCI Video Card - $62 Should be good enough to support my needs
LITE-ON Black IDE Combo Drive Model SOHC-5236V BK RTL - $29 Good reviews should get me what I need out of it. Having the option to burn CDs is nice in case I have to transfer data and since its only $8 more than a regular cdrom, why not
The last piece of the puzzle I need is an eithernet card preferably one w/both wireless and a port for a regular cable. any recommendations?
Total price looks to be around $900 What do you all think about the build, is everything matched correctly? any forseeable problems
