Hi,
so after all the excellent advice and guidance from my first post, here's what i've decided to go with(almost). Please give your thoughts about it.
The new machine be use mostly for home video editing(SD and AVHCD HD), some movies(e.g. netflix). The HDDs and optical drives will come from my old system.
CASE + CPU : Rosewill Challenger Black + AMD Phenom 555 BE OR CM 690 II case or Antec NSK4482B with 380W
Mobo: Biostar A880G+ OR Asrock 870 mobo
RAM : G.Skill 4GB 1333 DDR3
PSU: Antec 430W Green OR what? (XFX, Corsair, Seasonic SS 650HT, others?)
Questions:
1. is this system overkill for what i need? especially the RAM? should I go to 1066 or 800 DDR3?
2. Will the PSU(especially the Antec 380W) be sufficient if i'm able to unlock the 2 cores, and OC a little bit? how about if a new video card is added e.g. GT 220? Also, do these PSU come with some voltage spike protection( I may move to asia next year)?
3. is the Coolermaster case above vastly better than the Rosewill? I am like the latter because its smaller(3" shorter in height)
I will appreciate a quick response, at least about the case, the Antec 4482B has a $10 off promo ending tomorrow.
Thanks!
Questions:
Thanks!
