- Feb 9, 2012
- 23
- 0
- 0
This will be my first time building a pc. I have a budget of about $800. I need windows but already have a monitor, k/m. My current build would cost me about $850. So it is a little over budget but that is fine.
Power Supply - Antec hcg-520
http://www.amazon.com/gp/product/B0047YNHI2/ref=ox_sc_act_title_3?ie=UTF8&m=ATVPDKIKX0DER
CPU - Intel Core i5-2400
Since I am not OCing, I figured this would be a good choice.
Case - Cooler Master HAF 912 Mid Tower
http://www.amazon.com/gp/product/B003ZM7YTA/ref=ox_sc_act_title_3?ie=UTF8&m=ATVPDKIKX0DER
HDD - Seagate Barracuda 7200 500 GB
http://www.amazon.com/gp/product/B005CT56R6/ref=ox_sc_act_title_4?ie=UTF8&m=ATVPDKIKX0DER
GPU - Sapphire Radeon HD 6870 1GB
http://www.amazon.com/gp/product/B005C8RTTU/ref=ox_sc_act_title_4?ie=UTF8&m=ATVPDKIKX0DER
Windows 7
http://www.amazon.com/Windows-Premi...PT3I/ref=sr_1_1?ie=UTF8&qid=1328769497&sr=8-1
Motherboard - ASRock Z68 Extreme3 Gen3
http://www.newegg.com/Product/Product.aspx?Item=N82E16813157271
Ram - G.SKILL Value Series 8GB
http://www.newegg.com/Product/Product.aspx?Item=N82E16820231422
CD/DVD Burner
http://www.newegg.com/Product/Product.aspx?Item=N82E16827136240
I would like my build to run most games in High/Ultra settings. I also want to be able to upgrade it in the future when I get more money. My monitor is 1920x1080. Will all these parts be compatible with each other?
Would downgrading from an i5-2400 to a i3-2100 be worth it? That would let me get a 6950 2GB from Amazon. So I can get i5-2400 with the 6870 or i3-2100 with the 6950. Which would be better for gaming?
By the way, the 6950 is apparently the one that cannot have the shaders unlocked.
Windows 7
CD/DVD Burner
