- Sep 7, 2006
- 20
- 0
- 0
Hey guys,
So, I'm usually reticent to make my first post on a forum the requisite "OMG HELP MEEE111" post, but on the strength of a recommendation from a friend I've been assured that either 1) Anandtech welcomes such posts, or 2) Anandtech is used to such posts.
Regardless of whether you're willing to dispense help, or merely tolerate it, I'll give you guys my system specs, and give you as much information as possible regarding what happened.
THE SPECS:
Mobo - ASUS M2N-SLI Deluxe nForce
Processor - AMD Athlon 64 X2 4600+ socket AM2 (2.4Ghz)
RAM - OCZ OCZ268002GK 2GB Kit (DDR2)
HDD - WD Caviar RE2 400 GB WD4000YR
DVD - NECND 7570A DVD-RW
Video Card - EVGA GeForce 7900 GT KO (256 mb)
Monitor - Dell 2407WFP
I'm using an Antec SLK3000B ATX case with the Antec SO 45-0 Smartpower Power Supply.
BIOS: AwardBIOS v. 6.00PG
THE EVENTS:
Upon completing my build, and turning her on for the first time, the monitor remained in powersave mode, and I got the following shriek of pain from the mobo: one long beep, followed by two short beeps. After finding out this usually has to do with an incorrectly-placed video card, I tried reseating it. No dice.
So, I disassembled my system, down to just the mobo and the RAM. Turns out the A1 and A2 sockets on my mobo are not functional. Only after putting the RAM in the B1 and B2 sockets was I able to get a successful boot.
Once I reassembled everything and turned her on again, I got a vast array of frustrating, albeit superficially entertaining, errors. In a sample size of 18, here is a list of my errors.
THE ERRORS:
7 times, the system did not boot, and I got the "long, short short" beeps from the mobo.
3 times, the system would lock up as soon as I got a boot without the sounds from the mobo speaker. The machine would lock up with the "Ai Lifestyle M2N-SLI Deluxe" logo on the screen. Two of these times, the logo appeared as it should, one of these times, the logo had odd black and orange lines going through it, as though it did not load correctly or the image file was corrupted.
6 times, the system got to the point where it was reading from my reinstall CD. The following message would appear on my screen: "Setup is inspecting your computer's hardware configuration." Within these 6 attempted boots, the following errors were received:
2 times, the system would lock up after a successful boot, and the following interesting characters would appear down the left side of the screen (no, I'm not making this up):
Well, that's everything. I hope I wasn't too specific. Does anyone have any ideas on what I can do? Currently, I'm leaning towards the "motherboard is busted" and "get a new copy of WinXP" hypotheses, but any alternatives are welcome.
Thanks!
THE SPECS:
THE EVENTS:
THE ERRORS:
- 1 time, I got a black screen of death, without any sound from the mobo
- 2 times, the monitor would enter power save mode and the mobo would resume the long, short short beeps
- 1 time, I got the following message: "Line 11640 of the INF file \i386\txtsetup.sif is invalid. Setup cannot continue. Press any key to exit."
- 1 time, Windows setup actually started, but locked up.
- 1 time, Windows setup started, but informed me that "file ntkrnlmp.exe could not be loaded. The error code is 14. Setup cannot continue. Press any key to exit.
- a "u"
- a box with a crudely-drawn in smiley face
- a "."
- an accented "a"
- this one's hard to explain. Imagine an F, but extend the vertical line up until the bristles on the F appear in the middle, instead of the top, of the letter. Or picture a toothbrush with the top bristles missing.
Thanks!
